I did a quick mockup in React Native to show how I think a very user friendly way of changing the resistance when in resistance mode could be done. Basically all you do is press the Target square and up pops a slider. Once you click anywhere outside the slider the slider disappears.
One have to keep in mind that when using a phone and being tired and sweaty the controls have to be big, your fine motoric skills can be quite dampened.
Although I think this is an improvement I think it can be even betterā¦
Exampleā¦
If I am doing 120% vo2 max, i need to do mental math to figure out what % i need to lower if i want 115% on one of the repetitionsā¦ Yes I know its not rocket science, but if im tired and the rest is short (like 1 on 1 off repeats), i dont want to do that. It would be cool to show what the power would be after the changeā¦
Example i have an ftp of 250w and want to reduce to 95% the workout of 120% FTP/50% rests intervals I would like to see the new max/min power will be be 285/119ā¦
Sure. I dont think this feature is meant to be used in that way though, to apply a broad change to an entire workout isnāt really the purpose here, and progressions and AT will really help address things like that in the future proactively!
A quick additional request - an instant āreturn to zeroā!
Iām one of those people who often bumped up the recovery sections between intervals, or extend the cool downā¦usually because Iām participating in a Zwift event at the same time as using TR, and really helpful to increase the intensity to stay with a group, but need to return to 100% before the next interval kicks in.
The latest app seems really laggy when adjusting intensity - weirdly, getting worse as the duration of the ride increases and with the scale of the intensity increase. To be clear, Iām not fussed about a handful of % increases, Iām talking about taking it from 100 to 300% and then back down againā¦ and incredibly frustrating to overshoot things and end up below 100% for the next set of reps
Iāve always thought that instead of continuous press, adding a +10% and -10% to go along with the +1% and -1% buttons would have been the best way to accommodate larger adjustments. The new continuous press implementation is not only laggy, but now the simple +1% and -1% press is more difficult than it used to be (especially when youāre pegged).
The end of my workout I wanted to whack the % up for a quick sprint or whatever so press and held +, it shot up and I let go and it kept goingā¦and going. So then I did the same on the -, it went down, and downā¦and down, so then I did the + again, and it went up and up, then I did the āpanic finger tappingā to get it back down to ānormalā again. Was fun, but not the desired outcome
Getting āstuckā may be a device specific issue, I havenāt heart of any other reports of this received! Check in with support@trainerroad.com so they can run through any applicable troubleshooting and try to help out!
Why not just switch to resistance mode and do a sprint or whatever? Erg isnāt really intended for the use case you tried so non idea outcome isnāt really surprising
I see what youāre saying but thatās not the point. The point is, if I press and hold the intensity adjustment, as per the implemented feature request, it doesnāt stop when I release but lags and keeps adjusting for longer than required. Youāre suggestion may be a work around but I would think that both lead to exactly the same outcome if it worked on my device as intended. Example: if I press and hold while it goes from 100 to 200%, Iād then expect it to stop increasing as soon as I release it, rather than continuing to increase for āxā amount of time up to 300.
Would it be possible on the app (I use android) where you click at bottom of screen to adjust intensity to make it possible to enter a numerical value instead of only being able to hit + or - button? I ask because I often add sweet spot at end of a ride, would prefer to stay on erg but I have to his the +/- button like 100 times to get it from very low cooldown watts to sweet spot level. For example I had it at like 225% the last time I did this.
So this may be a redundant entry for one that is already in the TR FR library. I will leave this to @IvyAudrain to merge or leave separate as appropriate.
Im passing this along to the team for consideration for sure, there are no bad feature requests!
I should reiterate though that if this is a regular occurrence of changing efforts to 200+ percent, its probably better practice to just select a different workout to be honest, either via TrainNow, Alternates, or just selecting one from the Workout Library that looks more like the energy system youāre after by increasing to 200+ percent.
The reason I do this is 100% during cooldowns is like 40% of ftp and if Iām feeling good will add maybe another 12min sweetspot to end of a workout but I never know if Iāll add until Iām toward the end. So increasing to 200+% is only setting the watts at like 88% of ftp. But I often might add 30mins of endurance to end of a workout - and that usually is around 150-175% too. Not sure if that makes sense.
I have often thought that +10% and -10% buttons in addition to the current +/-1% is the best way to accomplish quick changes. It would take about two seconds to double one intensity with ten quick taps, and would avoid the awkward lag of the continuous press. Try running that idea by the team?
I honestly donāt do the intensity adjustments very often. Butā¦most of my indoor workouts are done at work on a dumb trainer
But at home I use the it a lot for cooldowns. I will add cooldown time, and lower the intensity. I accidentally tried to tap and hold the - button, only for it to continue scrolling down to 0% after I let go. So then I did the opposite and ended up at over 200% before I gave up.
Iām not really going to complain since it is something I rarely do.
I do often just do multiple workouts back to back myself. They are all recorded together on my Garmin.
Has anyone noticed that intensity adjustment feature is snappy, quick, and useful in the beginning of a workout, but becomes super laggy and slow near the end (over 1 hour)? Could this be a device issue on my part (I use an ipad), or is it something with the feature itself?
