i have a 2 weeks old Carbon Racebike and have noticed the following marks on the frame right below the seat post at the back fork leading down to the cassette.
What is your take? Is this a crack going to run deeper over time? should I accept this despite the bike being actually brand new? No crash or abuse or anything.
I’m guessing that’s the seat stay? Hard to tell if it’s a crack, but the paint certainly shouldn’t be coming off unless there was an impact or was scratched by something.
Tap it with a coin and then tap other areas with the same coin and see if they sound different (i.e the other seat stay). That looks like clear coat or paint issue but you can do simple sound test to help you make a more educated guess.
If it is that new and purchased from a LBS - most certainly take it to them also.
I wouldn’t accept if it was brand new, never ridden.
It does look like something got dragged across the frame there. Maybe something got kicked up from the road? It does look superficial. If the frame just simply cracked, you probably wouldn’t have the scratches across the paint. What are the bits of brown on the frame in that area? Dirt from the road?
I’d do the tap test as posted above. If there are no dead spots then at least you know it’s superficial. If this were a local bike shop purchase, you could have them look at it and see what they say.
The tap test isn’t infallible. In my experience it works pretty well across relatively even and unchanging stretches of tube but isn’t ideal for sections where the curve and thickness changes—like this spot.
This could just be paint flaking (what we’re seeing is literally paint), but it also has the kind of branching stochastic pattern you’d see on an actual crack. Either way, some trauma had to cause it, and on a brand new bike if that wasn’t you, I’d most definitely be taking it back to the shop. To me it looks alarmingly like the kind of crack you’d expect if that spot had been directly hit, hard.
Thank you all. I have taken it to the shop and they are looking at it.
There was no direct hit, no abuse or anything.
There was a little brighter spot on the same place already when I got the bike and I asked the dealer about it. He looked at it and mentioned it would be the usual change of color on carbon you find regularly all over the frame. True, there are these different shades on this mate black carbon frame.
But the original brighter spot turned into this and that makes me worry.
If there was a difference in the surface appearance then this and you already pointed it out to the shop I would think somewhere along the line someone tried to cover up either a scratch, chip, or other imperfection that is now visible. It was likely there before you purchased it, just covered up.
This sounds a bit dramatic. The smallest imperfection blown up in a digital photo often looks like some giant disaster.
Most people have nicks and scratches much worse looking on their 5 or 10 year carbon bikes and nobody is telling them that their bikes are unsafe to ride.
This could be a defective frame. I’m not denying it. Even if it was, I doubt a failure there would result in anything catastrophic. If this were my out of warranty, used frame, I’d do the tap test and keep my eye on the spot.
In this particular case, I’m glad the dealer is involved.
If it wasn’t like that out of the box (it wasn’t), then nobody is going to take back a frame that got scratched in some way.
Honestly, I’ve had frames scratched while riding out on the road and I never even noticed it until after the fact. Something gets picked up by the tire, swings around and smacks the seat stay right in that exact spot.
The spot was different from the very beginning and the vendor acknowledged this (I hope it stays that way).
I do not know, what kind of impact could have been there and cant imagine, what would have been picked up from the road to hit this very spot. I rather think it is a damage which was there from the very beginning and got bigger during ride, being exposed to my weight (90kg) and to stress while riding.
So that looks like a ‘void’, or porosity in the carbon processing. (The lightness was caused by no backup carbon or resin) Not at all a great sign for their manufacturing process, or their especially their quality control process either. True, most frame manufacturers will completely over process some spots in the frame like the BB shell area (I saw a Specialized frame that was replaced and they didn’t want the frame back, so the shop cut it into pieces to show the construction. The BB area was seriously over engineered) but that looks like the junction from the seat stay and top of the seat tube, so there is a lot of stress in that area. The vibrations would come from the wheel hub, through the chain and seat stays, so either that spot would fracture right away, or over time it would. Either way, having a seat stay jutting out under pressure while riding rough-ish terrain doesn’t sound comfortable. It is also possible that it would never fail, but the one issue with carbon fiber is that it doesn’t bend like aluminum, or steel. Yet it can show indications of imminent failure, but it can also show no indications on a visible level and yet suddenly completely fail.
I, personally, would never ride a bike of mine that showed any possible damage (that I didn’t know about before hand)
(I have a really old Trek Madone that has some damage on a seat stay. The core is visible through a small area where the overcoat is missing, and I can see they used solid carbon fiber rods for the core, so I’m comfortable thinking that they were over designed enough that the frame is safe for normal riding, but if I see the injury getting worse, it’s off to the wall in my garage for that bike, on display so I can see it and remember the great rides we had.
Scratch? That is damn near a gouge! And yet it looks like an air bubble that had the thin layer of resin (or paint) finally flake/slough off. From the angles of the pics, it could almost look like a crush mark where some of the surrounding material is raised above the indentations. Like I said above, it’s possible it’s porosity in the carbon fiber as it was being setup in the autoclave. If there’s porosity there, it could be almost anywhere as well. And if there is a bleb (a bubble) in the front of the down tube, or tot tube, that is a prime place for a catastrophic failure of the joint and a pretty dramatic crash.
I looked over the last two bikes I bought with carbon frames. I pointed out the clarity of some of the carbon fiber sheets in one area, but they were buried under enough resin. I bought both of them.
But buying carbon bikes used? (I know this is a new bike) Depending on what I was going to do with it, I might be more careful on looking them over…
