Crank length vs power
Assiomas send out power data (in watts) to head unit. In other words, crank length is already accounted when head unit receives the data from the pedals.
Assiomas use primarily crank length set in the head unit. If head unit is not available, they use crank length set in the Favero app.
Maybe instead of discussing it here someone should ask Favero support …:wink:
You can set the crank length for Assiomas on your head unit, or you can on Wahoo units.
