Like many, I have an older road bike on the trainer with a well worn drive train. Over the past couple of weeks, the front derailleur broke (no problem, found one on the 'bay for 20 bucks) and on the very next session, the rear shifter gave up the ghost. I’m not too keen on dumping good money after bad on this as the chainrings have also seen better days. So, ultimately I will replace the groupset on the bike… sentimental attachment to the frame.
Anyway, to my point. When swapping over the assioma pedals I noticed that the crank length was 170. I had always assumed they had been 172.5 because that is just what I had been running on other bikes and I was quite the novice when I had purchased this one way back when. My question is then, since I had set the crank length 172.5 when I set up the pedals and now have them on true 172.5 cranks, how would this effect the readings. Previously would the readings have skewed higher or lower then they would now? Or would there be no real difference.
