I thought I could just swap out my quarq xx1 cranks from my boost hardtail to my boost trail bike but it looks like it’s “dubwide”. Then I thought…just move the spider over but the bolt pattern is different.
What are my options here? Garmin pedals? Or is there a way to get a crank based powermeter on the trail bike? The cranks are truvative descendant fwiw. Thanks guys!
Power2Max NGeco fits on3-bolt SRAM crankarms. They use 4-bolt chainrings. That still is less $ than the Garmin pedals.
P2M are easy to setup and are a solid option.
Sigeyi AXO is a good option too. Costs less than Power2Max and is lighter, also very accurate. AXO is rechargeable, P2M uses coin cell battery (with a battery door that isn’t super secure but hasn’t been an issue for me personally). I have both and they’re both excellent.
If you have an NX crank (I just looked for a picture), it doesn’t have a flat surface on the back to allow for the pod to be installed. Same issue I have with my Race Face Turbine cranks.
I ended going with the power2max for $590, it’s a little more than stages but you get two sided power…which has to be better than one sided, right? I had a 1st gen stages XT crank arm, it worked perfectly so I like them…it’s just that I wanted two sides. And sometimes I might want to go flat pedals…so the super expensive garmin pedals weren’t at the top of my list.
I’m pretty sure power2max has a powermeter spider for you. Mine is a 3 bolt and they have one for it but I think they have the 6 bolt too.
