Wondering what sizes you are using for chain waxing. I know there is another thread but looking to get some recommendations.
Thinking about a 2L ultrasonic below that has 2 year warranty. Harbor freight has a 2.5l but 90 days. Not worried about heating as I will be using my electric kettle.
For crock pot does it need adjustable heat or just off, mid, high?
I have a 2L and for just a chain, that size is fine. Will work for most road cassettes, as well (up to ~36t, although youâll need to angle it in). If you are going to do large MTB cassettes, you may have to clean it twice and flip the cassette around for the second cleaning.
Remember to clean your cassette when waxing chainsâŠthe residual grease on the cassettes will ruin your efforts to wax a chain. Same with chainrings (although you can do those manually pretty easily with some degreaser)
I use a 2L ultrasonic cleaner, works fine (one chain at a time). Mine also doesnât have a heating element, but I heat the water to 70ÂșC in an electric kettle and that does fine (I havenât actually measured the temp by the time I finish a cleaning step, but it successfully melts the wax already on the chain so I think itâs doing the job).
For the crock pot, Iâm using a small one - 1.5qt - thatâs circular, and the chain fits. Mine only has âhighâ and âlowâ settings and it works just fine, but I havenât run it at âhighâ with paraffin in it over night to see if I accidentally burn my house down.
Thanks. I ended up getting a 2 qt crock from target today for 9.99 (high/low). Also got the Harbor freight 2.5l ultrasonic but might get one I saw one that has a 2 year warranty.
See below from Molten Speed Wax re: mineral spiritsâŠ
Because ultrasonic cleaners are powered by electricity, we canât recommend using flammable solvents in them like mineral spirits and denatured alcohol. Instead, choose water based (aqueous) cleaning solutions that are non flammable. When combined with heat these solutions clean extremely well with one exception: they arenât 100% effective in removing new, unoxidized grease from a new chain. If an aqueous solution is used in this situation a light film of grease will remain on the chain.
I have the HF ultrasonic cleaner, and it has been working well for me. Large enough for most things, but not super bulky.
I picked up a âminiâ crockpot at goodwill, which is perfect for 1 or 2 chains, and doesnât take much wax.
Walmart has paraffin, as will some other grocery stores. It is also used for canning, so any place that sells that kind of stuff should have paraffin. The brand I have seen there is âGulf Waxâ. Looks like some Ace hardware stores may have it as well. This should be pretty widely available.
Maybe I was in the wrong section as I did not go to canning. Reminds me though I need to get some more small mason jars so I can candy some more jalapeños. Yummy
Honestly my solution with new chains (if I didnât buy them waxed) is to just ride them for a bit, and turn that new, unoxidized grease into the mess I love to avoid. Then the ultrasonic cleaner with Simple Green HD is up to the task and the chain will be wax-only from then on (and I have a little bike clean up to do).
But also, Molten Speedwax and Zero Friction Cycling both seem to think that YBN chains get along great with an ultrasonic bath and wax from the get-go, so thatâs another option if (like me) youâd prefer to avoid dealing with mineral spirits.
