I think I understand CTL to basically be your average TSS per day for the last 42 days. If I understand that correctly then to reach CTL (or Strava fitness) of 100 you would need to average a weekly TSS of 700, or a daily TSS of 100, in other words average 60 min at threshold per day (or 120min at 50% threshold) for 42 days.
For TR, yes, they use rolling 42 day average of your TSS as their version of CTL.
Other platforms exponentially time-weight CTL, placing more emphasis on TSS of recent workouts, so it’s not always an apples-to-apples comparison. CTL itself is a TrainingPeaks term.
TSS calculation is not correct, however. You’d have to ride for 2hrs at 71% to get 100TSS.
TSS = [(time in s * IF * NP)/(3600 * FTP)] * 100
So TSS for that 50% two-hour ride =
[7200 * .5 *.5 / 3600] * 100 = 50TSS
You’d have to ride four hours at 50% to get 100TSS because in a perfect steady state scenario, IF * NP/FTP just squares IF.
I found this example helpful. So, for example, if you want a CTL of 100, you’d need to be doing approximately 15 hours per week. It’s a guesstimate, but in looking around, it’s pretty accurate.
Yeah, he has talked about using an average IF of .7 in thinking about things like this, and that’s pretty good when I look at historical averages for my athletes. On lower volume it might be a bit higher, like .74 or .75, but typically when you get up around 15hrs, a .7 or maybe slightly less average is decent, and that would get you a CTL in that 100 neighborhood.
FWIW, when I plug in long group or unstructured rides for people I typically use .7 as an IF to estimate their TSS going into the week to balance things and it’s usually pretty good (unless that person really thrashes themselves).
Yeah I believe the TSS calculation was designed for 1 hour at FTP being 100TSS as the baseline. Dr. Coggan would have to confirm that, but pretty sure that’s right.
Yes I was just trying to use that as an easy example for TSS, but I’m glad I used both examples because it highlighted that I thought TSS was a little different than it is. I really appreciate everyone’s input
Yeah I know the numbers work out that way, my point was he specifically designed TSS to be defined that way (such that 1hr at FTP = 100TSS) as the reference point, and as you know that’s what they said in TRWAPM.
I think the industry has moved on from season PLANNING with TSS/CTL because it’s a fool’s errand. The industry hasn’t moved on from FTP*** except for people for whom its in their interest to do so because they’re selling something else. **
TSS has its uses. Primarily I use it as a check sum, and it’s also a really good tool for long term REVIEW.
*** I would include FTP and critical power concepts in this same discussion.
** These are just my opinions.
I’d agree. I’m still looking at TR plans with an eye on the hours and TSS I’ve done in previous years to get a sense of confidence.
But only because Garmin make it difficult to analyse/manipulate EPOC load data. Which I suspect is much better. I also look at active kcal.
I outperform Friel/Couzens predictions on hours and bike TSS for a mid pack Ironman triathlete, by about 30%. I put that down to indoor structured training.
That’s kind of a funny story. When Andy first came up with TSS, he was trying to mimic the formulation of TRIMPS. He had a long series of steps which he posted to the old Wattage List. Then maybe a day later he decided to revise the definition with a slightly different weighting scheme, and revised the long series of steps. A couple of hours after he posted, someone posted with “Um, don’t all those new steps reduce down to 100 * duration in hours * IF^2 ?”
Hahaha. If that’s true, then that’s too funny. I’m a math and physics guy, so these manipulations are completely intuitive and immediate.
Recently, someone posted a review by researcher of Loughborough University that compared the Cricital Power model to a power law. I was surprised by the state-of-the-art. One or two of the authors were from their math department and they included (mathematical) propositions and had proofs in the Supplementary Material. (These were things you could ask math undergraduates and they should know the answer.) When I interviewed for a position there, I was told that the sport sciences department was quite good.
Yeah, I have never gotten into thinking of my training in terms of CTL ramp rates and the like, so this sounds quite alien (and indeed, archaic) to me.
Do you have any alternative that is better? I’m seriously asking.
I am not aware of another metric that is as universal as FTP (feel free to lump in CP). For most athletes, i. e. those that are not on the shallow part on the top-right of the S-curve, FTP (however you want to define/measure it) does strongly correlate with all other performance metrics. Whenever I hear replacements, refinements or some such bandied about, I almost always think “The juice is not worth the squeeze.” — except in certain select circumstances.
