Favero Assioma’s now report Garmin’s Cycling Dynamics information after the latest Firmware update today (4.04)
Will the Cycling Dynamics information be available through Trainerroad as for Vector pedals?
@gpl , have you ever replaced the pedal body on your as ASsiomas? If so was it difficult?
I struggle with the release tension being too high on mine, I have to get it in the correct postition and still may take more than one attempt. Favero have released a new pedal body with 8-20Nm tension that you can buy for 130Eur a pair.
Don’t mind the price for safety if it’s easily fittable. Can’t find any manuals on there website.
Thanks as always.
Will there be a video about your experience with this? I am curious about which applications will let me view the data. Thanks as always!
130 Eur a pair? I was interested in getting the new pedal body but not at that price.
130 Euros is crazy money for spare bodies from pedals that only cost 79 Euros new! (Xpedo Thrust NXL)
You don’t need any of that anyway.
Remove one of the springs from the existing body and you’re good to go. The axle slides out after loosening off the bolt on one end. Don’t pull it all the way out, remove the spring and then slide the axle back in and everything is much looser.
Mike
Are you using Xpedo or Look cleats? The Xpedo cleats are slightly thinner and feel normal to me. I got a pair of Look cleats and almost broke my ankle just trying to unclip!
It’s not clear from the thread so far. Will the portion of cycling dynamics they’ve implemented appear on the TR UI? Will it only work with an ANT+ connection or Bluetooth as well?
Will give it a go next time I’m feeling mechanical. ![]()
We have not had the chance to test the Assiomas yet with CD, but if Favero followed the Cycling Dynamics protocol to the letter, it should be able to work with the existing implementation. Let us know it works for you
Cycling Dynamics is only supported via iOS and ANT+ at this time.
I’ve done this last week and finally release experience is a it should be.
Highly recommend this tweak.
Hi Bryce,
Is it likely that it will be released on the windows desktop app in the near future?
Cheers Scott
I was wondering that too! I might just have to do a test
Thanks for mentioning that it is only recorded on Garmin head units. I guess I will be waiting around for Wahoo to enable it. I have been rehabbing a hip injury and was curious about the different patterns for each leg.
We do not plan to bring Cycling Dynamics to the desktop versions
Sorry I don’t have better news for you.
Update: We have tested the new Assioma firmware in house with Cycling Dynamics on iOS/ANT+ and it works ![]()
What about Android Bryce?
Not at this time unfortunately. Cycling Dynamics is only availiable on a small number of devices, so a majority of our users would not be able to use this feature if we were to spend the extensive development hours required to make it a reality on all platforms.
That’s very disappointing. Needing to run a head unit in parallel to capture all the data for a workout creates a syncing nightmare.
Man, that’s super disappointing. Even if it means still collecting the info and allowing it to be exported out to another program like GC. Instead, you have to win the lucky-dip “which version do you use” prize that I find all too common with TR.
