Vibrations are present in almost every brake system but itās when the vibration oscillations increase in speed to a point at which the frequency becomes audible to the human ear that it becomes an issue.
yeah itās really bad. itās basically embarrassing to brake around people. I shout out to people ahead of time that Iām sorry.
I have tried *EVERYTHING. baking, scrubbing, rotors that cost 25% more because they have black paint on them, resin, metal. upgraded to the dura-ace brake system, new lines, etc etc etc etcā¦
Itās more about keeping them clean. Some pads leave less residue than others but as far as I know all pads and rotors are susceptible to squeal.
Rotors are very sensitive to any kind of contamination. That includes skin oils. Thereās a high chance of transferring any kind of residue, even if you donāt touch the breaking surface or use gloves.
While itās important to clean them frequently, itās better to avoid direct contact.
Edit: sometimes trying to get rid of the squeal makes it worse because you can contaminate them every time you manipulate them. So, itās a vicious cycle.
It sounds contradictory but the point is to do the least to keep them clean.
What kind of bike do you have? My LBS mechanic gave me a quick lesson wrt brake noise. Facing could be an issue. On my cervelo he beleived it wasnāt a problem⦠so we didnt look at mine. After a messy brake bleed job, he soaked my rotors and pads in alcohol and a little oven treatment and they are great. Actually until this recent teardown, I never had brake whine, just rub I couldnt figure out how to fix. He also showed me how to to micro adjust caliper position.
Almost anything works, as long as itās clean and correctly set up.
If youāre getting recurring issues, either itās alignment as per above or the caliper seals may be leaking - not necessarily a noticeable amount, but enough to contaminate everything. If you think this may be the case try sticking a bleed block in, packing around the caliper with tissue and zip tying the lever down overnight, then see if thereās any residue in the morning.
I donāt know if Gorillabrakes ship to the States but Iāve been very impressed with their Enduro Kevlar pads on my gravel bike for their lack of squeal to endurance.
I went through this on my first disc brakes - a Bullitt cargo bike that I rode through the winter. I eventually figured out that the caliper seals were leaking. I could tell because I would find circles matching the pistons on the back of the pads. That was the mineral oil that was causing me so much trouble. I replaced the front caliper and the problem has gone away. It was a hell of an intro to disc brakes.
Chances are itās getting contaminated by grease/oil/fluid from your own bike leaking, you are contaminating things while cleaning /living your bike or is from the road during use of transport.
Not tried their rotors but really like their brake pads. So much so that all our MTBs are now running them. Cant remember last time I heard squealing brakes even in the wet.
So every time you get disc squeal, you clean your rotors? Do you also change the pads? Not changing the pads had been an issue in the past ⦠my LBS mechanics insisted they could be sanded down, but once that gunk gets in there itās in the pad for good in my experience.
Also, for a rotor cleaner/degreaser nothing, and I mean NOTHING, works as effectively as Dawn dishwashing soap. Iāve used simple green and other muc off products in the past, but nothing works as well as a bunch of Dawn in a little bit of water. I just had to do this yesterday with my MTB that has Deore calipers and Shimano rotors. Something got on the rear disc and not only was it wailing, it had lost 95% of its stopping power. I cleaned the rotor with Dawn, and did the TP test (thatās my term ⦠I take a single square of toilet paper and run it over the inside and outside of the rotor ā if there is any residue of anything at all on the TP, I rewash the rotor) only took 1 pass, swapped the pads and it was good to go.
Also ⦠and this is a random aside ⦠4-5 years ago I was struggling with chronic brake squeal that kept popping up every two weeks until I isolated that it was always after our cleaning service was at the house. Turns out that the workers were wiping down my bike with Windex or Pledge or something.
