Easton EC70 Aero Road Bar Wiring Question
Hi- I’m looking to purchase Easton EC70 Aero Road Bar’s but I want to make sure the wiring will work. I’m using Shimano ST-R8150 levers which need to be wired directly to the Di2 Battery. I was planning to wire the levers together and then I only need to run 1 wire back to the battery. In order for this to work I need to be able to run a cable through the bars from 1 lever to the other.
It seems like these should bars should be able to to that but I was wondering if anyone has experience with these bars and can verify. Thanks!
They are hollow all the way thru
Perfect. That is what I was hoping to hear. Thanks!
