On the website, would it be possible to show the Personal Record graph (the power curve) for the highlighted interval data when one is selected, please?
For comparison, the Power Zones table does update dynamically.
Hi @IvyAudrainâŚwhen clicking Details and then looking in the âAll timeâ view for 3min I see
Hope you understand the difference.
So you see something like
There are reasons for both variants.
But I would strongly suggest to add the second view (which I expected to see at first and was a bit confused to see something different) ![]()
Hi @IvyAudrain,
My analogue is the Power Zones table below, or the interval data to the right of the workout graph. When a specific interval or time range is selected in the workout graph (at the very top of the page), all other metrics on the entire page are then filtered on that data - as if the workout were just this section. Currently, the Power Curve is the only thing which doesnât filter on that subset of data.
Adding this feature would mean that you could select one lap of a race, for example, and see the best 1-min, 3-min, 5-min etc. power for that lap only, as opposed to the best power for the entire race/workout/ride.
Thanks
Seconding @Rizziâs request here too.
The current Personal Records details is âx-min Best Power Progressionâ rather than âTop x-min Powersâ. The progression is useful as it is a generalisation to any duration of the current FTP History feature in the Account page. @Rizziâs Top x-min Powers feature would be useful to add in order to see how frequently youâre hitting numbers close to your best, and in what sorts of workouts or races.
GOT IT! Thanks for chipping in, all. Will pass along to the team for consideration, I can see how this would be a useful tool, but not sure if/when it would get on the roadmap. Iâll certainly update you if it does! Cheers!
Just checking that youâve got both requests here: my original one, and Rizziâs Top x-min Powers one.
Thanks
Jeep, thanks. The more I think of it the more puzzling it gets:
If I set my best 3min power 10 years ago I wonât see anything after that any more. Even if I set second/third/forth/fifth/⌠best 3min power in those last 10 years. The chart becomes a bit useless for older/aging athletes. That doesnât make sense especially as the Header is âAll timeâ for Personal Records.
I see that a workaround would be to look up that dialog for a desired season and then go through the list in the âweeklyâ tab.
Dialog definitely needs a bit of enhancement and polish.
