First Power meter: What now?
I finally pulled the plug and got a Favero Assioma Duo. What are the first things that I should do?
This is what I’ve done so far:
  1. Calibrate
  2. Set a powerpage on my wahoo (1, 3, 5, 30 secs)
  3. Use intervals.icu to see some extra data in addition to strava/trainerroad
Things I plan to do:
  1. Re-take the ramp test
Questions:
  • In the test I did on TrainerRoad, with 3 secs it seems more erratic compared to the Kinetic InRide 3.0. Should I adjust it to 5 secs?
  • Assuming it’s possible (I haven’t checked yet), should I use both my head unit and my phone when using TrainerRoad, in order to gather more data?
Am I forgetting something?
Not really sure where it’d fit in but I’d suggest getting some outdoor rides in with it so that it’s less abstract. It shouldn’t take too many rides to get a general idea of what you’ll get for different wattages.
Smoothing is a matter of preference to some degree. I use 3 second for TR (though I swear it’s less smooth than my garmin which is also 3s). If it’s too jumpy you’re not missing anything by switching it to 5. The powermeter should be able to sync to any number of devices. They’d see essentially the same data though.
Definitely make sure you’ve got the crank length set correctly for your pedals in the Assioma app and the same for your wahoo. Enjoy, I’ve been using the Duos for going on 2 years and have had a great experience with them.
its an electronic device. Update the firmware
Done! Thanks for pointing it out
This is probably a silly question but… how do I do this? I tried searching online, but couldn’t find it, and I don’t think I’d be so precise if I were to measure it myself.
Wake up your pedals
Open the Favero app
Find your pedals using the magnifying glass in the top right corner
Connect to your pedals
Update firmware
For the smartphone app and for wahoo:
Crank arms have the length printed on them. Look around, probably near where the pedals bolt in. Probably says “170”, or “172.5” or something.
You can pair eg your head unit with the pedals, and your phone with the trainer, and then run TR from your phone. That allows you to collect the power data separately, and is useful to see how much of an offset is between the two. You’ll only need to do that once or so, to see the difference.
If there is an offset, the easiest way is to activate powermatch in TR, and to pair the pedals as the power source. If there isn’t an offset, it doesn’t matter that much, you could either run the trainer as before, or use powermatch.
I think “Become obsessed with small variations in L/R balance” needs to make the list… probably not too long after your first ride.
Thank you, I learned something :slight_smile:
Looks like I’m at 49/51, so pretty good :wink:
Does TrainerRoad record Right/Left data? I don’t think so, but maybe I’m wrong.
My only reliable source of power is the powermeter, so it probably wouldn’t make much sense to compare it to a dumb trainer that I already know not being very reliable.
Ah, I didn’t realise you had a dumb trainer, in that case, forget about powermatch, just record the data however it seems easier.
Set up your head unit to show the PM battery level (not a Wahoo user but I assume its in there somewhere). You can go just long enough between charges that its possible to forget.
Great idea!
I would start with this but can be too much as a first step:
This. This is the most important thing.
Outside of simply doing a zero offset and ensuring your crank length is set correctly, don’t do anything else. Just ride as normal and casually pay attention to your power numbers. As you noted, 3-seconds is erratic. I use 3-second as my instant power, and then 10 and 30-second averaged power for my ‘what am I roughly currently doing’.
Look at how things feel in different conditions, at different intensities, and different cadences, and based on different days of the week with fatigue. Simply put: Just passively collect data for a while.
Ultimately, you want to build up a bit of a mental correlation between how these powers feel, and what the numbers show. So that eventually you get to the point where mentally you look at your power and go ‘Oh, right, I can’t sustain 350w for the next 3 hours of this ride, maybe I should chill out a bit’.
Enjoy!
Wow… quite an honor to see your name here :slight_smile:
Thank you for chiming in!
