Hi,
I have recently changed rotor and brake pads on my Shimano Ultegra Di2 bike. I was struggling with some issues with the dura ace rotor and metallic pads, so went with campagnolo rotor and swissstop resin pads, now completely quiet again ![]()
However, my issue is that sometimes when I brake and then pedal to re-accelerate, the front rotor makes a rubbing noise, clearly it’s rubbing against the pads, when I then press the brake again, it goes away… this never happens on the rear…
What do you think this could be? And how to fix it? I have checked the rotor position and it seems to be quite well aligned, when I spin the wheel, it doesn’t make any rubbing noise at all…
Any idea? Thanks so much for your help! ![]()
