FTP Estimate Confusion
Hi TrainerRoad,
I’ve been having some wild swings in my FTP estimates from different sources and I’m not sure if my training is working and whether I’m training productively.
History:
I first started using TrainerRoad in early 2024 and used it until May or so, then took a break from it for the summer. Signed up again December 13, 2024. Since then I’ve had wildly inconsistent FTP estimates:
  • Dec 3, 2024: Took a ramp test on Zwift: 260W
  • Dec 13, 2024: Started TR training plan, increase FTP. TR AI Estimate: 281W
  • Dec 20, 2024: I failed a workout, TR adjusts FTP down to 275W
  • Jan 27, 2025: TR AI Estimate: 280W
  • Feb 5, 2025: TR Ramp test: 247W
  • Feb 5, 2025: Manually adjust FTP to 260W because excessively low and I was recovering from a cold
  • Feb 10, 2025: Start a new training plan, increasing FTP
Most recently, my workouts have been feeling a bit too easy. Yesterday I had a VO2max workout and I already rated it moderate.
So basically, I’m confused about where my true FTP is really at at the moment and whether my training is working at all. AI estimates always seemed to be a bit on the high side to the point that I was failing workouts. I’m inclined to discount the recent ramp test because I wasn’t feeling optimal around that time but it’s leaving me unsure about where to set my FTP for optimal training intensity.
On the other hand, in a real 1h threshold effort like the Alpe du Zwift my recent best was 246W on Dec 6 and only 222W on Feb 12 (didn’t ride the whole segment all-out after I blew up a bit on the first three bends).
Pick a method (preferably the classic test or other long form test)and apply it consistently to gauge progress. Eventually AIFTP will produce more accurate results given sufficient training history.
Rule of thumb - the only types of workout that are useful for calibrating your FTP are (best) Threshold and (OK) Sweetspot. Anything else is too far away from your FTP to tell you very much.
I used to struggle with the 20 minute test. Now I do the longer form Kolie Moore test. It’s way more reliable and way easier to pace.
You could confirm your 270. I just use the baseline test. By 30 minutes into the test I know I can “feel” my FTP, meaning that if I go a little bit harder I wouldn’t make it very far but if I back off a bit I could go for a significant amount of time - “about an hour”. I usually just do 30-40 minutes because by then my FTP will have been sussed out. I make no effort to game the test like I used to do with the 20 minute test. I mean, everybody goes all out for the last few minutes of the 20 minute test, right?
Once you start doing a long form test, it just becomes a good FTP workout.
Like the 20 minute test, ramp test, it is an estimate of your FTP. In my experience a lot better estimate than either of those if you’re giving it good data. One that is even better though is a long-form test like the Kolie Moore tests where you can get to the point where you can feel it. I can ride for 20-30 minutes and tell you what my FTP is on that day, and it’s just a threshold workout.
Seriously though, let’s not get into the actual definition of FTP, that blows up every thread it’s talked about on. What is important about it is a basis to benchmark training zones, measure progress, etc.
Is it possible to do this in the Trainerroad app?
There are custom workouts in Team Gold workout library.
My favorite way to dial in and validate ftp is doing an over/under workout. ~95% unders and ~105% overs. Overs should be feeling progressively harder through the interval, unders should be uncomfortable but sustainable.
And if you are just using ftp to base your workouts on, getting close is close enough. Basing workouts on a percentage of ftp is super squishy to begin with and progression levels are there to help dial in the right targets.
This is one way for sure. I think I might prefer something similar but not so mixed. Take what you think your FTP is (we’ll use 300W for a round number). Then do several 10 minute intervals around that number, increasing in intensity.
So you might do:
  • 10m at 290
  • 10m at 300
  • 10m at 310
I’ve done that several times in the past and it’s pretty clear when you’re over FTP vs just under. Your effort will start to increase, breathing gets more ragged, etc. This way the ‘over’ and ‘under’ are more distinct and you don’t have to worry if the ‘under’ is so hard because it’s actually over FTP or because you’re recovering from the ‘over’.
But all these are good ways and for me the key is to be consistent in how you test or feel out FTP so you have a good frame of reference each time.
Yep, that all makes sense. I don’t really schedule O/U workouts as FTP tests so much, I just find O/U workouts effective and they give me FTP validation as a byproduct of doing them.
How much rest between each interval?
Zero.
I prefer to do a warm-up then start out at FTP minus 10 for 10 minutes, you want this one to be an under. Then go right to target / test FTP for at least 10 minutes, 15-20 Better. Then increase by 5-10 W every 10 minutes or so until you’re clearly going VO2. You should be able to feel where you go from threshold to an “over”.
Last week I did what I thought was FTP minus 10 for 10 minutes - completely fine. Added 10W. Next 10 minutes was fine, was convinced that was my FTP, then all of a sudden over the next 5 minutes (15 minutes total) it became pretty clear I was about 5W too high. HR just kept climbing. That’s why I like more than 10 minute intervals if you’re close and trying to dial it in.
Then in subsequent workouts you can test +/- 5W for 20min or longer. For me, I have a pretty good read on how my heart rate, breathing, and RPE responds up to FTP, and as I go above it.
Also - I need to be fresh for these. Working at FTP is a hard workout and you don’t want the RPE to be messing with your read on your threshold.
When I’ve done it it was over a long ride so there was like 20 minutes or so between. I think that’s fine if the jumps are big enough between intervals but would be too much to suss out smaller differences. I’ve done them after a VO2 block so I was hopeful for a decent FTP bump and was more interested in whether it was like 325/330 or 335/340. Then my coach prescribes threshold workouts with a range where I can more fine tune by feel. So when I did it I felt that 330 was close to threshold but 340 was definitely over so my coach then prescribed threshold workouts as something like “3-4x15 @ 325-335W”.
But I agree with @BCM that a variation could be to mash them all together as that would make it quicker to recognize when you’re over FTP but it also could present the problem if you take too many steps to get to FTP then TTE can become an issue (are you over FTP or is your new TTE just lower).
But both can be used in the same way and it just comes down to individualizing the workout/test.
The one thing I’ll say - 10 minutes isn’t enough for me to tell if I’m over if it’s only by 5-10W. Take my recent test. Did 10min at FTP minus 5-10W as a warmup. Went directly to FTP+5W for 10 minutes. Felt completely fine. It wasn’t until the next 5 minutes where it started to hit me that I was over and heart rate started to spike. 10 minutes will tell you if you’re in the ballpark though once you get used to it.
The approach I recommended is effectively Kolie’s Baseline Progression that was shared above.
