FTP Test Froze Up?
Not sure if I did something wrong, but the dang thang froze up on me right at the start of the 20 min block. This is my first legit FTP test so I figured not seeing your power might be part of it, and hit it hard for 20 min just going off my watch. Really hard effort for me, kinda disappointed it didnt work.
Email support@trainerroad.com if you havenā€™t already done so.
I also had my workout freeze today, and happened after app update so possibly a bug but equally may just be a coincidence
Iā€™ll initiate a line of communication with support to check it out, be on the lookout for an email from them!
Hey! Looking at your outside workout from today, I dont see an interruption in your power profile, can you explain what you were experiencing so we can better help?
Was it a Garmin screen ā€˜freezeā€™? Since youā€™re referring to the app update, did you load a different workout on mobile or desktop and experience issues?
Thanks in advance for clarifying!
Hey Ivy, thanks for jumping in.
I was doing Taylor-2 on the Trainerroad app (indoor workout), but i normally record on my garmin too. The TrainerRoad app froze mid-ride, then unfroze then kept freezing again. I had to close the app and then jusr quit the ride. I think you are looking at the garmin file, im not sure if the Trainerroad file has been uploaded from the app yet so you may not be seeing it.
The update notice was on the TrainerRoad app, it mentioned ā€œworkout instructions no longer read outā€ and ā€œother under the hoodā€ updates.
Hope this helps.
Edit - TrainerRoad workout from the app now showing. I will leave it for a while but then delete out one of them to avoid duplicate ride.
Got it! Thank you for explaining that, Im going to go ahead and initiate a support communication for you as well to try and isolate the source of those app issues and get you training again! Be on the lookout for an email. :+1:
@IvyAudrain
The FTP test is quite buggy and it also crashes regularly for me at exactly this point (probably about 1 in every 5 or 6 tests). I guess there is some issue in the code around switching automatically between ERG and resistance mode.
Anecdotal observation is that itā€™s worse if I have paused or changed device settings (resistance amount) earlier in the workout leading up to that point.
If the devs want to play about with this without spending hours on the bike, then I can also make it crash here by simply pausing the workout and using the scrub feature. It will often crash the moment the scrub ā€œbarā€ touches the start of the test block while Iā€™m still dragging it.
In fact, I have just tried on my phone now at my desk, not connected to any devices. It crashes every time I scrub forward to the start of the 20 test block
Android: 11
Motorola moto g(8) power.
Have you contacted support@trainerroad.com directly for them to review your issues?
I havenā€™t. It is the same issue as the OP, I just wanted to add my +1 with some additional info in the hope you can resolve whatever bug is causing this.
Please send directly to that email. The forum is a secondary place for bug reports, IMO.
Nothing beats getting it into their actual tracking system.
While what youā€™re experiencing may be similar, the root cause may be different and require different troubleshooting.
Iā€™l go ahead and initiate a support communication for you as well so the team can take a look!
I seem to have virtually the same problem. Iā€™ve been using the 20 minute test for two years but have only had this issue for the first time six weeks ago, and again yesterday (see screenshot - canā€™t be a coincidence). I was using a Bkool trainer connecting with Ant+ but since I switched to a Wahoo Kickr via bluetooth Iā€™ve had the problem. I already have a support ticket for this but I would have hoped, if it is a bug, it would have been fixed by now. Not the end of the world as I can do the ramp test instead, I just ā€œlikeā€ the 20 minute test and have had good results from it.
Iā€™m sorry for the trouble, youā€™re experiencing a similar issue because this is still an active bug that the team is working on.
Iā€™ll provide an update on this thread when weā€™ve released the fix, and Iā€™ll communicate your experience to the team as part of the bug report.
Until that fix is released, you can always go for AI FTP Detection instead of testing by enabling the feature (instructions here), schedule a Ramp Test for today, and accept the AI FPT Detection result when you open the test.
Alternatively, Iā€™m happy to just go ahead and run the AI FTP Detection for you and provide you a result via DM so that you can manually update your FTP instead of finding another test protocol, or adding another test to trigger the AI FTP Detection result. Let me know and Iā€™ll gladly send that over!
Thanks Ivy, thatā€™s really helpful. Iā€™ve enabled it myself.
No problem! Happy to help, let me know if you have any questions while youā€™re getting started with that feature.
Unrelated: your workouts and Progression Levels and survey responses are looking stellar. Youā€™re absolutely crushing it! Keep up the solid work. :muscle:
