1.5 lbs. gained in a matter of hours is just water weight. Drink more water, eat some asparagus - problem solved. ![]()
I reckon there are 0 forum posters and podcast hosts saying to fuel a < 2hr Z2 training ride with 100g of carbs per hour.
That’s interesting. Are you simply saying upto 25% less of the sugar is absorbed and it sits in your stomach before passing through, or that your absorption rate is 25% lower than someone who’s had a high carb diet for years?
Oh, I fuel longer Z2 workouts. If I’m going longer than 3 hours, I’ll have things to eat during the ride. I always have snacks with me on the bike, regardless of the length. I’m not religious about not fuelling my Z2 rides, if I feel the need I’ll have a snack.
During the lockdowns in the UK I did some long Z2 rides without fuelling to see where my limits were. I carried snacks for when I was hitting those limits. I then experimented with what’s the minimum amount of carbs I need to consume an hour to maintain performance at Z2. I found out that answer on Z2 rides up to 10 hour duration.
I’m off on a 4-5 hour Z2 ride in about an hour. I have no intention of not snacking on this ride.
Because I ride ultra distance I’ll find my limits now and again. For ultras it’s useful to know where they are, and how far you can push it. For instance if the 24hr garage isn’t open at 3am, can you keep going till something is open in the morning, or do you need to stop and sleep as you don’t have enough food supplies for the next leg?
I also think it is genetic , and some of it is exercise induced. In other words at rest your absorption maybe the same as another person. But during prolonged or intense exercise your absorption may dramatically drop whilst theirs doesn’t.
Because ultra distance involves prolonged duration even if at a relatively easy effort, stomach issues are a common complaint later on. Reducing the amount you need to eat to fuel these events goes a long way to coping with the reduced gastric emptying.
“As exercise intensity and duration increases, there is considerable evidence for increases in indices of intestinal injury, permeability and endotoxaemia, together with impairment of gastric emptying, slowing of small intestinal transit and malabsorption. The addition of heat stress and running mode appears to exacerbate these markers of gastrointestinal disturbance. Exercise stress of ≥2 hours at 60% VO2max appears to be the threshold whereby significant gastrointestinal perturbations manifest, irrespective of fitness status.”
You did mention decades of bad high sugar diet though, which is impossible for teenagers to achieve.
Ain’t that the truth! I tried, and failed.
Yeah, some people get extremely caught up in trying to prove a point. Maybe i did too? I think your post very accurately describes my approach.
Nailed it. ![]()
There are no absolutes of always doing this or that. I add sugar with salt and citric acid to bottles depending on a few things. For example:
If I skipped breakfast and doing a workout before lunch, will always add sugar. About 60g per hour for shorter Z2 seems to work. And if going a bit faster/multiple hours will bump it to 80g- 100g in each bottle regardless of having had breakfast or not and might then start adding solid carbs too.
Depending on the temperature, might add 1g to 3g of NaCl to each bottle.
If I did have breakfast then I might just drink plain water for shorter Z2 rides or just add in 20g to 40g of sugar per bottle.
I am able to ride multiple hours without eating on the bike if I needed to, but it is just not enjoyable as RPE starts going up. There is just no need and typically I am eating only 25%-50% of calories consumed during the ride, sometimes balancing on the edge of fueling just enough to keep the RPE from going up unnecessarily.
There is a lot more to fluid retention than sugar intake.
To be fair - I wasn’t suggesting I fueled all Z2 workouts at that level, nor that everyone should. I was merely giving an example of where fueling at that level was helpful for me.
If you have an FTP similar to mine and are doing Z2 workouts to start your day (straight out of bed) then I would recommend trying it, but I did not intend to suggest all of my Z2 rides were fueled like this, or that it would work for everyone
Woah, my bad! I made a bold assumption without reading all 286 replies. Lesson learned. ![]()
What I get from this whole thread, (at least, the bits of it I’ve had time to read, lol) aside from a bit of amusement and cringes is that there are many ways to go about fueling z2 workouts. Why there has to be so much mud-slinging and disrespect towards each other is what I don’t understand.
When I was a newb, I hadn’t the slightest idea about fuel, hydration, let alone electrolytes, etc. I just came home from each ride ravenous, with a massive headache, then I would head to the brewery for a couple beers and no food. For TR podcast to remind people to fuel, preferably with carbs, is probably the responsible, intelligent thing to do. If you are in the low carb, low fuel camp I guess this is cringeworthy to you, but it doesn’t matter - you do you!
As for me, I take a moderate approach, taking into account all kinds of variables from my daily life. From time to time, I will try both extremes just to check and see if they are better or not. (And what I’ve concluded thus far is that any more than 90 minutes with no fuel is sub-optimal for me - but that’s just me, a person none of you know).
It’s interesting to learn about all of the different substrate pathways and all of the different options you have for fueling. But I go with my intuition and what works for me based on experience. Mainly because the vast majority of the subjects for all of these studies are men, so women are basically flying partially blind in all of this.
That’s a super important point. I reckon the baseline should be 20 % lower for women, just on account of the weight difference. @Dr_Alex_Harrison has a fueling calculator app that takes gender and various other factors into account. I currently use it and it works very well for me. I override some of the recommendations (e. g. I drink way more than he recommends), but I just know that I need about 1.5–2 bottles per hour (currently on the lower end since we have winter and I don’t sweat as much).
@OreoCookie this is amazing user feedback! Tell me more! What sweat rating are you typically choosing? Have you been comfortable following the sodium recommendations? We can move the conversation to DM’s or the thread for the app specifically if you like.
Eventually we hope to have the biggest women’s data sample size in history. My wife will be helping design the research. Will be very neat to share the findings with everyone once we’ve got something useful to share. If you’d like to contribute to the end of flying blind, we have an app in beta testing you’re welcome to sign up for. We’d absolutely love to have you! Of course, there will be informed consent when it comes time to publish and very optional opting in to anonymous data disclosures just like we do in a research setting. That’s a bit down the road for now though.
+1
The app is getting better with time!
I leave the sweat rate at the default. I just know from experience that I should prepare about 2 bottles per hour indoors. Outdoors, I take two full bottles and refill as necessary. The recommendation matches what I consume outdoors in temperate climate, i. e. about half of what I drink indoors.
I have a question regarding the sodium recommendation: my kitchen scale has a 1/10th g accuracy mode. But adding e. g. 350 mg is not possible, so I treat the recommendation as a minimum. Not that I try to go beyond it by much, but it might happen that I end up with, say, 500 mg = 0.5 g in my bottle rather than 0.35 g. My thinking (correct or not) is that I should take in a certain amount of sodium.
I don’t think too many people have a scale with a higher precision than 0.1 g, and I don’t plan on getting a precision scale for that either. Perhaps you should not use sub 1/10th g precision.
Lastly, I noticed that your carb recommendations went up. I assume this is to do with Podlogar’s study that you covered on your channel? For the record, that has been working very well for me.
PS Is there a way to contribute to your app/channel? I’d be willing to chip in a few ¥/€/$ per month e. g. via Patreon.
PPS I liked the video that dropped on your channel today.
Dissolve 1 g of salt into 1 liter of water.
Then every gram of that water that you measure has 1 mg of salt.
Sure, but just think about the quickest way to do this, especially without wasting water: you’d weigh all the ingredients on a scale in the bottle. At least that’s what I do. I of course zero the scale after putting my bottle on it.
Just use the water that’s left to cook your rice in the evening, the salt will add flavor.
If you don’t want complexity just round it to the nearest 0.1 g yourself and realize that it falls well within all other uncertainties to compute the range of salt that is good for you.
Very astute observation ![]()
I know that this is technically correct, table salt being NaCl and all. But is that how I am supposed to read the instruction? I don’t think you could expect regular people to know that they need to scale up going from Sodium to salt. (I am well-versed in STEM and that didn’t occur to me.)
But I think one way or another, I think your observation raises an excellent point: one way or another, I think @Dr_Alex_Harrison’s app needs to be tweaked here: if he really asks me to add x00 mg of sodium and I need to multiply that with 2.5 to compute the amount of table salt I need, he should change that to table salt by default instead. Or he should change sodium to salt in his instructions.
The app now reads table salt in grams of the actual salt, or by teaspoons of salt. Or you can switch it to sodium citrate if you like. Either work and either give grams or teaspoons. You can toggle between each all on the Prep screen.
We launch publicly in January so if you’d like you can chip in then! Until then, let me keep polishing it up a bit.
ps. thank you! Glad you enjoyed that. Tip of the iceberg. More to come.
You really iterate quickly. The change should clarify things. @Bbt67 really had eagle eyes there. Good catch! ![]()
PS Keep us posted on your service. (You might even want to touch bases with TR staff and ask if you could announce your service here. If not, feel free to DM me.)
