Can someone help me with the proper set up,
Tacx Neo, Garmin headunit, Vector pedals and a garmin HR sensor.
I would like all the stats from Garmin connect and trainer road.
And a Mac.
Is it possible without Strava showing both rides?
And a Mac.
Why record on the headunit? Are you running Trainer Road on the Mac? Doesn’t it control the Tacx Neo and link to the Vector pedals?
Others may know better than I do, but as far as I know, if you want a workout to go to Garmin Connect, you can either record the workout with a Garmin, or manually export the workout from whatever platform you’re using and manually import it to Garmin Connect. I should add that when you import a ride/workout to Garmin Connect, that circumvents all the performance metrics and tracking that Garmin will provide with rides/workoust recorded on a Garmin. As you’ve found, if you record the workout on two systems that are linked to Strava, then Strava will show them both, at which point you can delete one in Strava to eliminate the duplication. That’s probably the simplest and easiest thing to do.
Add your Connect account to your TR account, and the workouts automagically go to Connect.
Thank you everyone for your help, Once I used the ant+ dongle everything worked without using the head unit.
