Anyone able to get True Up to create Training Load from non-compatible devices, as per this 2018 update?
“ Collecting Data from Devices that Aren’t Compatible
Even if one of your devices doesn’t support this update, the activities you record on it will be sent to your compatible devices* through Garmin Connect, so your VO2 max, training status and training load numbers stay up to date.”
I have a fenix 6S Pri and Edge 530+ which are compatible, and a Forerunner 45+ which is not.
I should be able to get Training Load from activities on my 45+ through Trueup….
Mine used to show a vo2 max for each, one for running and one for cycling. I don’t see that on my phone anymore (I haven’t run in a year). If you look at reports in Garmin Connect’s web interface you might be able to see both of them there:
Every couple of months or so since I got a Garmin Vivioactive watch GC seems to record two VO2Max numbers. Ive never set the watch to record though and it would only go of a optical hr monitor which I don’t rate).
Tried the FR45 with my HRM Dual for a ten minute run. Opened it up on the Fenix 6S Pro - no load information, doesn’t show up in Connect Training Effect either.
