Definitely getting swim/bike/run:
I think it might be because tre Fenix 5 series doesn’t support all the load functionality ![]()
Just in case anyone is interested, I tried Zwift Run using the Fenix 6S Pro recording as a virtual run, transmitting cadence and HR to Zwift. Pace was from the iPhone Runcline app.
The resulting data from Zwift into Garmin had none of the load metrics you’re looking for.
@dcrainmaker I just noticed something that I am unsure if its an issue with how they build this or just a bug. It looks like if you use a watch that does not support power (245 in this case) it will not update the training stats until you turn on a device that does (edge 530). Logically this makes sense, the 245 does not support the features required to do the math even if it has the tech to do so. If you can reproduce this with other devices it seems a worthwhile mention in your writeup.
I continue to regret not getting a 945 for many small issues like this that have piled up over time. I should really just sell the 245 and upgrade but I just cant quite be bothered.
I am another one of those not seeing load:
– outside run with HR on 2/21/21
– 2 TrainerRoad workouts with HR (broadcasted from Fenix 6)
– workouts show up in connect and watch but no load calculated
FWIW, I haven’t trained outside for quite some time so my watch is currently showing “no training status” at all. I’ll try running to see if having existing data is a pre-requisite for calculating load
Looks like I’m back to having to dual record. Tried only recording on TR the last week but not getting training effect for those workouts in GC.
So I think I have a different problem. Anyone else? I’ve been running just TR on my laptop and (auto) syncing to Connect after the ride for the last week and a half. I have a Fenix and Edge that also sync to connect. I just noticed today that every ride I’ve done shows as “anaerobic”. Today I did White-5, a 60 minute easy ride. Garmin shows IF of .68 and TSS of 46…but classified the ride as Anaerobic with a benefit of “sprint”.
Is your FTP setting correct on the garmin side? (The IF and TSS make it sound correct but can’t immediately think of anything else.)
That is a little weird. I’d check your heart rate zones for that device
Yes, I thought of both of those too. Both correct. I’m going to run side by side for a few rides and see what happens.
I’m guessing this means others aren’t seeing the same behavior though, so not sure what to do to actually “fix it”. Is it on the TR side or the Garmin side? ![]()
Can you screenshot the Anaerobic and Sprint classifications? Maybe also the exercise load screen from Garmin Connect showing a few rides?
Hi all,
I have checked my TR ride data is flowing into my Garmin account and it has all the ride data under the activity section but doesn’t populate anything in the training effect section under the performance stats group. I also noticed that my VO2 Max is improving with my training but the cycling VO2 Max doesn’t update unless I am doing an outdoor ride with HR and the power meter. I would have thought that the TR indoor sessions would drive the cycling number up in line with the other one?
Does anyone know what I may be doing wrong or is this normal, thanks heaps.
Have you done the two-way sync with your garmin device that you use for cycling?
I think it would be on the garmin side because it’s how they are interpreting the ride data they are getting? This is of course assuming there’s no crazy HR data on the rides that have been classified as “anaerobic”.
Hey,
The only Garmin device I use when doing an indoor TR workout is a Tacx smart trainer. This and my power meter synced for the two way power match thing and then I have a Bluetooth heart rate meter. All of these devices are connected to my phone that I use for the workout. Once the workout is complete the activity shows up in my Garmin account on my phone. This is where I view my VO2 and load etc. I hope this helps.
I’m also not sure what they two way sync feature is.
Update: I did a ride tonight with TR on my laptop and Garmin 1030 side by side. The Garmin data populated properly, so I just deleted the TR ride. Hopefully they fix it soon.
Hi, definitely on the Garmin side. Can you show us the ride data from Garmin connect for the activity. It will be interesting the see the time in zone data from the bottom of the graph tab
Motivation to be better about syncing my watch now I guess!
Nice catch. Sure enough, the ride from Wednesday that was only recorded in TR, White-5, shows up in that graph as 90% in Z1+2, and 10% Z3, but is classified as “Sprint”
The ride from yesterday, that I ran on the Garmin, Tallac-4, is properly classified as “Threshold” and shows 25% Z1+2, 75% Z3+4.
So I have the workaround, but the question is why the TR data is being incorrectly classified in Connect. And again, no one else is seeing this? Odd that it would only be happening to me.
