Not sure if this is a TR issue, Garmin issue or me issue but if you look at the image below you’ll see the interval workout graphic is significantly lower than it should be. The purple arrow points to a line representing my FTP of 284. The red arrow points to an interval of 550w and either side of that interval is 185w.
I’ve done scores of workouts outdoors and this is the first time it’s happened.
did it stay that way the entire ride? Or just for the ~2 minutes of the real-time graph window? It looks like what happens when you put down a quick 1000+ watts, and then settle back into riding. Except there is no obvious power spike.
entire ride. in fact. when I finished the workout, i uploaded the same workout for a second time and the same thing happened (I completed the workout twice)
Updated a few weeks ago. I did wipe old TR workouts saved on my Garmin recently though. Today’s workout was uploaded this morning. Seeing what happens if I upload a workout now.
First time I’ve seen the entire profile of a workout before. Maybe it’s because I haven’t started the ride. Will have to try and start a workout in the next few days.
Not sure if this is related, but I have a friend who, after every workout, the zones in Connect look far below his threshold, even if he does VO2 work. It looks like every ride is Z1. I actually thought he did it on purpose to make it look like he wasn’t smashing every ride, but he swears he’s got everything set up correctly.
It’s been happening for a long time though, not something new.
Do the zones look correct in Connect, only weird on the head unit?
