Goo Gone on Carbon Rims
I got a set of Roval carbon rims and I couldn’t get the stickers off cleanly. Can I use goo gone to remove the residue or should I find a different way?
hair dryer on low heat is the best way that I’ve found, if you do it before you remove the sticker the whole thing usually comes of in one go, used the same trick on tubeless rim tape today
(melts the glue so that it easy to remove / comes off with the sticker)
