Gravel tyres with TPU-inner tubes
Hi,
Looking for input on gravel riding with TPU inner tubes. Not keen on tubeless, is this a “worse” option than regular butyl tubes? Grateful for input.
TPU is supposed to be more puncture resistant. However, some TPU tube makers had issues with tubes failing at the seams / valve and gave a bad impression early on.
For better or for worse, it’s the way I’m going this season. I don’t have tubeless wheels so I have to run tubes of some sort. The TPU tubes offset the extra weight of a Redshift stem.
I’ve had great success with the Tubolito X-CX and CX lines. The CX are lighter, but I like the X-CX because Tubolito will stand by them with a one year warranty.
I race a lot of fast, rocky gravel roads but have not had to use the warranty yet.
Why aren’t you keen on tubeless? If you’re already running 60psi or less the improved grip, puncture resistance, and reduced rolling resistance of tubeless are a no brainer. Even if your wheels aren’t tubeless you can probably set them up ghetto tubeless with a 26” inner tube or a rim strip.
What tyrepressure do you use? Your weight is?
Sounds good to hear that you are happy with them!
Its a bit more hassle, when theres no actual room for this kind of procedures at home, so thought I might get a bit of tubeless benefits by using TPU.
Love my Tubolito’s on the road, never had a flat with them, but lots of flats with butyl.
My LBS recommended them highly as being stronger and lighter than butyl, so I’ve just switched to them.
I ride tubeless and carry TPU tubes as a backup. However, if I decided to go back to inner tubes I would most likely choose latex tubes. Latex has low rolling resistance, is very comfortable and also more puncture resistant than a butyl tube with the same weight.
I ride 48 in the front at 49 in the back in Perelli Cinturato Gravel H tires. I weigh 157lbs currently. Have been really pleased.
