I’m being tempted by a road bike by a local shop’s closeout pricing on Cannondale Synapse Carbon 2 models. Stock is low, so I’ll have to make a decision this weekend.
They have the Carbon 2 RLE and Carbon 2 LE models priced at $4,542CAD and $3,999.99CAD, respectively. The more expensive model has Varia radar and Ultegra Di2 vs. no radar and 105 Di2 on the lower priced model. Wheels are different, too.
My conundrum is sizing. The RLE is only avail in 51cm, which is aimed a folks starting at 5’5" and the LE is is avail in 48cm, where the size range tops out at 5’6". I’m just under 5’6" and relatively long-legged (30" inseam jeans).
Riding the 51, I feel as if I’m stretched out, but I’m not sure if that’s because I’m used to riding nothing other than my mid-travel MTB (2021 Pivot Switchblade in Size Small).
Comparing Geometry:
Bike | Size | Reach | Stack | HTT | Seat tube Angle
Synapse | 48 | 371 | 530 | 533 | 73
Synapse | 51 | 376 | 550 | 544 | 73
Switcblade | S | 430 | 614 | 592 | 75.5
Looking at just these numbers, my instinct is that the 51 could be workable whith a shorter stem. I don’t know the OE stem that comes with it, but it is not integrated with the bar and has a normal 4 bolt bar clamp, so swapping out should be eay. It looked to be longish, certainly a lot longer than the 45mm unit on my Switchblade.
But, is going with the 51 the right thing to do, or should I “suffer” 105 Di2 and a boring black paint job and get the 48?
I’ll be test riding the 48 tomorrow and should be able to back-to-back them. I’ll bring my pedals and shoes for this, but given the high probability that my sub-conscious will push me to the 51, is moving to a shorter stem just a band-aid, or viable idea?
Disclosure: this would be my first drop-bar bike EVAR and it would be used on road and on the TacX Neo2T. If you know of any challenges fitting the bike on that trainer, please let me know.
Links…
Geometry Geeks geo comparison: Compare: Cannondale Synapse Carbon 2 LE 2023: 48.0 -VS- Cannondale Synapse Carbon 2 LE 2023: 51.0 -VS- Pivot Switchblade 2021: S -VS-
…to bike on Cannondale Website if anyone want to see more of the geo or spec.
RLE (51cm) option: Synapse Carbon 2 RLE | Endurance Road Bikes | Cannondale
LE (48cm) option: Synapse Carbon 2 LE | Endurance Road Bikes | Cannondale
