Hello, I’m having trouble interpreting how I should be doing strength sprints. I just finished Daughhetee, which was my first workout with strength sprints, and have priceless coming up. The instructions state that there are ‘3x10s Strength Sprints followed by 6 minutes of Tempo’, and that I should start ‘from a near stop’. The power profile however goes from Tempo directly into 10s of high power (no obvious stop), followed by a sharp drop and gradual build before plateauing at Tempo.
Is the spring portion during the 10s of high target power? In which case do I slow to a stop and set my gears before hand?. Or is the 10s of high power giving me time to set the gear, followed by the stop and build back up to the tempo (with the build from very low to tempo being the sprint), although the interval time is then longer than 10s.
I have reviewed the ‘Drills - Efficiency, Strength & Power’ article but there wasn’t any further details given over what was included in the workout details.
I switched into resistance mode for these sprints (TR workout details recommended slope mode - hence the gear changing)
Any advice would be helpful, Thanks!
