I know this is how the battery is attached to the crank but is this an issue?? What about washing the bike etc. is there any cables that will be exposed?
Thought I’d ask in here in case I need to return it to the seller
Inside there will be connections coming from that battery. If you remove the chain rings you can get a better idea of the damage. If it not too bad a crack I would smear some superglue over it to seal it back up. I believe it can be removed but I have never done it. It is prob bonded after the wires to the strain gauges are soldered.
Shows briefly how Stages make left and right but not something that’s very instructional.
That’s correct. Is this less of a problem? I’ve heard about the latest ones are an estimated and not that good. With this being a 9100 and a Precision Pro, it’s dual sided. I should of been a bit clearer
the 9100 crank is asymmetrical. This means that any power meter will read wrong. Doesn’t matter if Shimano, Stages, or anyone else made it. It will be wrong.
The 9200 crank is symmetrical. Stages PMs have been shown to be accurate. However, the R9200P has been shown to be a load of hot garbage.
Just a thought, is the left crank still okay to use solely as a power meter? If I took the battery out the right hand side and use the left crank only. I could put it on my TT bike…
*We’re yet to see the 4iiii P3 R9200 dual reviewed (and released for sale), so I’d cool the jets on that until we do. As it stands the R8100 Dual and R9200 Dual from Stages would be the best option.
Hey, yeah I ended up buying the 9200 by Stages last week after the conversation I had on here with a few members, you review confirmed I was good to go ahead with the purchase too so thanks
I’ve still got the 2nd hand Dura Ace 9100 I bought from eBay and I was wondering if I should keep it and put it on my TT bike BUT use the left side power only. I wasn’t sure if that was inaccurate too
EDIT: I’ve currently got a Ultegra Crank arm with a 55t chain ring on and a Shimano 105 5800 4iiii left arm power meter. Hence why I was thinking about keeping this and using left power only etc etc
