I want to spend some time working on increasing my peak 5-min power.
Is doing classic 5-min VO2 max intervals (i.e. 4x5 min @ 115-120% FTP) a suitable workout to do to increase peak 5-min power or is there something more effective.
I know that workouts for increasing peak power are different than those for increasing repeatability. The latter generally involve shorter intervals with a 1:1 or 1:0.5 ratio for work and rest whereas peak power workouts involve significantly more rest and fewer intervalsāstriving for complete recovery between them.
My 5-min power taken from my last ramp test was 417w @ 82kg. As an experiment Iād like to increase this, but have never worked on this aspect.
Check out the progressions in Sustained Power Build High Volume plan. Tuesdays are generally VO2. Thursdays start with longer VO2 at 105-108% and progress to longer Threshold. Saturdays start with over/u sets and progress to longer Threshold. Sundays are long SweetSpot.
Thanks, but Iām not looking for a plan, but more specific workouts that target increasing 5-min power.
Iāve done a bit of internet searching and most training articles related to 5-min power focus on classic VO2 max workouts. Iām curious if this prescription is effective in increasing power at 5 min or if thereās a more effective workout.
Based on your ramp test result, I estimate you could go 430-450 W for 5 minutes.
Pick a target power in that range, on the higher end if you feel like you over-test on ramp tests, and see how long you can hold it. Give it a go and report back. Otherwise, youāll have no idea whether the specific training you plan on doing was actually productive.
To increase five-minute power, I would think you need to do workouts with intervals in the 5-10 minute range, which is low VO2 at the five-minute end (105-108%) and threshold toward the ten-minute end (100-105%).
Again, to train it, youāll need a progression to keep forcing adaptations, and I think the workouts in the SPB-HV plan can a good set of examples to consider, even if not following the plan.
Increase your peak 5 min power, or increase repeatable 5 min power? How many times do you need to repeat it?
Answering those two questions will tell you if you need a more anaerobic focus or more aerobic. The 1x effort has a huge anaerobic contribution, the more times you repeat it, the more aerobic it becomes.
In my case, the biggest gains to 5 min power were the combination of VO2 max block and threshold workouts. But it was only growing organically by doing only the threshold block. Nothing fancy to be honest - I have never targeted peak power of 5 min as a separate goal but it was growing naturally (currently sitting at 5.65 w/kg so according to WKO - excellent).
According to the chart in WKO 5 min power is 86% aerobic so I do not know if the 14% is such a huge contribution. It is big but doing more aerobic stuff will contribute more.
Try this one, roughly based on a Gordon Wright intervals session.
Start with 6-10 full gas 1min intervals, with full recovery (5 minutes) between each. Ride easy for 10-15 minutes, then do 4x5min full gas.
The power in the 4x5min will be lower than normal because the 1min intervals deplete your anaerobic tank. But this does mean theyāll focus on pushing your aerobic system to its limits.
Then when you approach a single 5 minute interval fresh, youāll not only have trained your anaerobic contribution, but trained your ability to ride hard when that anaerobic contribution runs out.
My biggest increases to 5 minute power have come from maintaining a high cadence. I would not neglect that aspect. Itās hard to keep a high cadence for 5 minutes. I started at 3 and built up because it would tend to drop off after about 3 minutes. Iād guess I added 7% just by not dropping off cadence at the end. Shorter intervals you can brute force through even if cadence drops off and over longer intervals it doesnāt matter so much.
Yeah, once again TP puts out incorrect information about their very own metrics. Iāve seen Coggan emphasize again and again that FRC is not purely anaerobic. To calculate the latter, youād have to base things off of VO2max, not FTP.
I did a specific 5 minute effort about a month back where I beat my old 5 min PR of 396w from January by 30w. My previous best was also from the ramp test - my FTP had come up about 30w too since the ramp test, but my short power was definitely lacking.
I did a 3 week block of 2 x VO2 and 1 x very high IF anaerobic workout. For me it felt like a case of getting used to the pain again. I knew when I was knocking out 9 x 3.5 min and then 8 x 4 mins at 393w 8 times that a 5 minute PR was inevitable. I used an interval in ERG mode to test it, which probably restricted me by a few watts, but we always feel that we couldāve done more once itās overā¦ I managed to do this after a ramp test, where I bailed after about 18 mins (wasnāt feeling it, and wanted to keep some powder dry).
FWIW I always ride the trainer at high cadences, especially high end intervals. For VO2, I aim to not drop below 110 rpm. It really helped me stay on track with the longer intervals.
You wonāt increase your 1 minute power by working in 1 minute intervals. You need to do something just above that power level in order to build itā¦ You need to work on raising the ceiling versus getting more efficient under the ceiling.
Weāre on a seemingly similar plan. I have nothing to target this season on than some local Strava segments and most of them fall in that 1-5-min range; so I thought it would be a fun duration to work on. I also think that having really good 3-5 min power can be very effective in winning local races.
Iām more interested in working on breakaway power, or what I consider peak 5-min power. The efforts you see in either establishing a breakaway or a race-winning attack. My thought was that I should do 5-min intervals as I would in a classic VO2 max workout, but have more rest in between them in order to fully recover. So something like 4x5 min @ full gas with 10 min rest between intervals.
This sounds awesome. I never would have thought to lead the workout with a series of 1-min full gas intervals and then wrap it up with 5-minuters. Thank you.
I came off a Polarized block that had me doing 2 VO2 max workouts weekly, one of them being long-duration intervals. I started at 4-5min. I think these really helped, but Iām scratching my head wondering if 5-min of rest between intervals is enough to fully recharge in order to hit the subsequent interval fully rested. Iām not sure it is, hence my original question. Thinking that doubling the rest interval might help set up the next for a truly full-gas effort. Less about repeatability, more about eeking out the max amount of power possible over 5-min. Hopefully with no power degradation from the first to the last interval.
Makes sense. Like in FTP intervals, weāre going slightly below the duration weāre targeting, but weāre hitting higher power in order to drive up maximal power at that duration.
For me, being able to do fairly high power repeats at 115-118% for a slightly lower duration (Mist +1 & +3) which would be very hard to do as 5 min repeats seemed to build my 5 minute power. When youāre knocking out say 30 mins of higher power work in a session, then you know youāll easily be able to knock out 1 x 5 mins at 125%+. I think this is the same point @Captain_Doughnutman is making
IMO some anaerobic sessions would be valuable for all out efforts in addition to VO2 workouts, especially for your sub-goal of establishing breakaways. Again my workouts were repeats (Coldblow +2, San Joaquin +7 etc), but āStripedā and its variants look better for building capacity.
Of course I do think specificity would work for you. I hit 10.19 w/kg 1 minute power last year just by chasing a LOT of short duration KOMs. Iād probably leave at 5 mins between this type of short effort. For a 5 minute maximal effort, Iād probably leave 10 minutes between intervals even though itāll probably get boringā¦
This is all anecdotal so prepare your grains of salt!
