Indoor Cyclists: Turn the fans off!
This thread is genuinely difficult to read and people are drawing some fucky conclusions from a dodgy chatgpt.
Exercise induces temporary hypotension; blood and volume is shuttled into the intracellular space (muscles etc) IOT do WORK. This is partially to blame for the stimulation of post exercise increases in plasma volume. It isn’t the increase in plasma volume causing hypotension but the other way around. You’re probably just dehydrated.
Adaptations are a mixture of central and peripheral. Alveolar membrane permeability? Central. Skeletal muscle capilliarisation? Peripheral. Cardiac hypertrophy? Central. Mitochondrial efficiency? Peripheral.
If you’re still struggling, imagine the worlds strongest man doing alp d’huez. Plenty of muscle, poor ability to supply it sufficiently and clear out metabolites.
Cooling reduces the central stress load, enabling you to elicit more peripheral adaptations.
If you remove cooling, you increase central load. You also make it more difficult to elicit peripheral load.
Peripheral adaptations take a long time. Central ones can be stimulated temporarily. This is why heat training is done by pros close to events, not aLl tHe TiMe GuYs Ur WeAk.
Think of it like altitude training. Are my 350 watts at sea level fake watts cos I couldn’t do them at 3000m? No, don’t be silly.
Also you can do heat acclimation without training at the same time and the plasma volume gains max out after about two weeks and plateau no matter what you do (only got so much space in that body bro).
Tl:Dr Do you want to sweat a lot and spend a lot of money on electrolyte tabs or do you want strong legs?
Turn off the fans? What could go wrong? :rofl:
Obligatory mention that anyone leaving buckets of sweat on their bike and trainer better add some serious maintenance to their calendar :stuck_out_tongue:
Galvanic corrosion is no joke and it can happen right under your nose with no sign of an issue until you hear and feel ‘SNAP!’.
This is not correct.
ETA: For example, an untrained individual can close the gap in muscle respiratory capacity to that of an elite athlete by ~1/3rd in just 7-10 d:
“One inconclusive biopsy marker of one peripheral adaptation can be acquired rapidly”
“All peripheral adaptations can be acquired rapidly”
“Peripheral adaptations are generally slower to respond to stress than general ones”
How are you getting on with that 200kg back squat after a week of training? Managed to induce angiogenesis over lunch?
You might be mildly irked by my flippant reply, but “this is not correct” is mostly just an unhelpful contribution to the discussion. So in the nicest way - you have so much more to offer!
My suggestion is that you do a bit more reading before posting any more misleading statements.
The fact is that the body adapts quite rapidly to changes in demand, something that John Holloszy, arguably the father of exercise biochemistry, believed was an evolutionary necessity.
Did you know that it takes less than 2 wk to increase your muscle capillarization? (That’s the earliest anyone seems to have looked in humans, based on the research I did last night.)
First I will state upfront, I am no expert in any of these areas. Setting aside any specific efforts for heat adaptations (in which case I would recommend listening to the Performance Process Podcast) the base premise of this thread seems to fly in the face of everything I have heard or read over my 20 years of endurance training. Which I will simply state in my words that positive stimulus is better than negative stimulus.
Given an equal RPE - which do you think would be better for you? Doing your 2 x 20 at 300W or 340W? Kolile Moore often uses the phrase on his podcast that “your muscles know the difference.” And that seems logical to me.
However, if you really want a challenge, please share your experiences on my other threads: Indoor Cyclists: Quit Hydrating! And if you really want to boost your performance: Carbs are cheating and make cycling too Eazy!
Less than two weeks to have the ability to identify statistically significant markers of angiogenesis. We can all misread research; in fact it takes almost no effort.
Do you actually contest my position that by ignoring cooling whilst training you are sacrificing peripheral adaptations by overloading the central thermoregulatory systems? Is your position actually that we should be doing all of our training in a sauna? Can I quote you on that?
We can all read, but apparently you didn’t. The increase in CD31 demonstrates that angiogenesis has taken place.
Note that there are other studies of humans showing an increase in C:F ratio after 2 wk, as well as others showing an increase in the capillary filtration coefficient (a functional measure of total capillary surface area) just as early. You would know this if you had bothered to do a little bit of research, as I did.
As for your conclusions re. heat stress, as someone who is a co-I on an NIH grant investigating thermotherapy, I will just say this:
You are not correct.
Wouldn’t increased plasma volume from heat adaptations increase cardiac preload and therefore elicite more cardiac remodelling? (The other way is of course true, a decrease in circulating volume decreases preload and pump efficiency)
Phone broke yesterday so I couldn’t use the roku private listening mode this morning didn’t want TV blasting while everyone else was still asleep, figured good excuse to do a little test with no fans.
Yesterday I did Pioneer-1 turning fans on about 5 min into ride like normal, lasko about 4ft in front of me at standing chest height with vertical nozzle and 2 vornados on the floor under bars aimed up. Felt great even though I was already doing an alternate I think .2 up from the recommended workout.
Todays workout was not planned actually, so I am fully aware that some of what I Was feeling was fatigue and also once again I pushed the WL a little jumping up .4 from yesterday so it was still productive. The workout, old black, was very similar profile just bumped up a little. As you can see avg watts over the ~45min was only up a little, HR was up quite a bit though and I felt it. HR was actually about what it was during the KM FTP/TTE test sunday (which i felt wasn’t getting high enough).
This felt WAY harder than yesterday. I added 15 minutes to the cool down and now still 20 minute later sitting here at my desk in just tri shorts trying to cool down. Maybe the suffering has some benefits but man my immediate feedback is F that.
Off to amazon to buy another accurite temp/humidity gauge for the gym.
I’m not sure what kind of facile straw man you’re chasing after here cog; but the position that serum biomarkers of physical adaptation can be detected in statistically significant quantities following exercise should not be a surprise to you (or anyone else).
I am, admittedly, curious as to how you equivocate “the presence of immune growth mediators are detectable within 2 weeks of exercise” with “all peripheral adaptations occur more rapidly than central ones”, but for the sake of the thread and for everyone else trying to avoid thy vitriol:
Is your position above that all training should be conducted under heat stress as the combinatory effects of thermoregulatory challenge stimulate total adaptations that outweigh the fact that the athlete must train at a significantly lower objective load? Can you offer anything to support this if so?
My only response to turn the fan off is f&*@ you
Yep; starling’s law applies. I’m not sure if I meant to give the opposite impression; merely that you can’t keep increasing plasma volume indefinitely and you can do it pretty well without actually even training in the heat (sit in a sauna etc)
For me at least training with less fan is much more convenient than going to the sauna or training in real heat. Although I need to figure out how deal with the sweating as things get real slippery and during rest/z2 intervals I get really cold due to the sweat
Anyway increasing stroke volume takes a very long time so I could see a benefit of staying heat adapted
If anyone would like to test the “no fan” theory. I would invite you to try it out in FL during the summer. Outside is a balmy 86, humidity is in 98%. Indoor you are blasting the AC and while running it cant cool the house to lower than 73. IF you try to do a wo on that conditions, indoor room tem will get in the 80s without a fan circulating air… i can guarantee it will not end up well for you, maybe a short easy ride… but a tempo/ss/vo2 ride? nope… you will stop no matter how much liquid you try to take… it will be too much… and even if you finish, you will feel like trash for days…
Save the heat training for the Z2 rides… and leading up to A events.
Work Intervals need to be at the optimal temperature imo, not too hot or cold.
It was 38F for my session today so no fan except the last 26 minute interval of three at 91% ish (actually I turned the fan on half way through the second interval but off before the recovery interval, for the reason you mention, freezing during the rest)
As heat adaptation is fast you only really miss out on 2 weeks of proper training but having a high circulating volume can make your heart more efficient thus training better and the volume can eventually make your heart bigger leading to an even better performance
So, is the scientific consensus then that heat adaptation is good but you only need to do it within about two weeks of when you think you need it? Can any good come from extended heat adaptation or is that a waste of sweat?
