Inside Ride Kickr E-Flex Trainer Motion System
I’m using a Robert Thru Axle and long hex wrench.
Should get my eflex next Friday going by tracking. Wonder how it will change things for me
First impressions.
Was expecting a small box based on the above. Got a very well packed box bigger then the kickr box. Way lighter then I thought it would be. Setup wasn’t so bad and seems like the instructions improved since chad’s setup based on what he complained about.
Should have listened to bbarrera as I got the thru axle they recommended instead (DT-swiss ratcheting lever) which is a much nicer thru axle then what came with the bike and I’ll use it when I attach wheels but a pain to use with this. They could easily fix this by having a cut out in the thing the thru axle goes through in the front so that you can use your finger to keep it from spinning in the direction you don’t want when trying to screw in or unscrew.
Getting on the bike the first time felt slightly unsteady but figured it out pretty quickly by just using both hands on the handlebar.
First actual riding it? Felt weird. The front and back movement was nice though. The weirdness turned into feeling a bit asymmetrical, not in a feeling like I’m leaning to one side but more that one side was doing more work then the other. This I think is from not being very careful about how I setup the device. Normally when setting up the kickr you don’t worry about how perfectly aligned the front wheel is when you get started where a degree or two off center is fine because it will get aligned as you bike. With the eflex your handlebars will get aligned but that slight shift in the handlebars will also lean it bike a small amount leading to asymmetry. Did attempt to fix this during the ride
Standing on the kickr feels so much easier now. Before it was always so hard to do so generally ignored TR when it told me to stand.
By the end of the first ride (45 minute Scott Peak so mostly z2) my butt felt so much better then before after a trainer session. So much more comfortable in that regard. But my knees on both sides felt a bit sore, sort of in the area where the vastus medialis meets the knee (medial side on the top side of the joint). Not exactly sure what is hurting, thats just to describe the location. Its not a bad pain, but felt like a soreness that could get worse. Not sure if this is a sign of something bad or stabilizer muscles getting engaged for the first time as the only riding I’ve done since March was on the kickr.
Thanks for the detailed post.
To the pain, I think you may be right about using more body and muscle than recent work on the rigid trainer. Give it a ride or two more and see how you feel.
Make sure to “take control” of the handle bars and actively ride the bike. Not doing that is a common issue with new rocker users. Get active on the bike now and it should make the ride more controlled.
Keep us posted and let me know if you have setup or use questions. Happy E-Flexing. :smiley:
I had the engineer/owner of InsideRide build my E-Flex and install my KICKR at their headquarters. From what we discussed during setup, the important things to be careful with initial setup are: 1) the measurement of the center leg of the KICKR, and 2) which direction you choose for the silver leaf spring (correct direction depends on which model year KICKR you own)
As far as getting the front wheel straight, I like to lift my handlebars just enough to pick up the entire front wheel E-Flex frame and align to make sure my stem is perfectly straight under zero load before putting it on the ground and riding to avoid that asymmetrical feeling you described @enki42. My front E-Flex frame is very close but not perfectly square to the rear frame because of the tension bands, but if I align it under zero load as described above, it operates as if it were square or parallel with the rear frame of the E-Flex and KICKR.
I’m happy to hear you share your experience regarding feeling unsteady or what many people fear regarding tipover. I really hope more people weigh in on that as I find it very unfortunate that Ray planted that seed for many folks. If tipover were an issue, we would be hearing about it here and in the DC Rainmaker review comments. I haven’t seen any reports of people falling over on their E-Flex, but I’ve read multiple people asking about a redesign. I love the small footprint of the E-Flex and still feel a larger footprint or stability redesign is a solution looking for a problem.
:+1:t3::+1:t3::+1:t3:
Really stable and I’ve left it unlocked. Only once have I felt like it might tip over, when reaching for something to my left.
Absolutely agree. I forgot about that as I have NEVER tightened that nut and feel it is completely unnecessary.
Absolutely. Just got on the bike like it’s not on a trainer.
If you want to get really OCD on setup, here’s mine:
  • Detach fork from front Eflex, and lock the front so it doesn’t rotate
  • Put a tape mark on the side of the front Eflex, so you know exactly where front / back neutral position is
  • Connect fork back to the front Eflex - the front left / right should still be locked out
  • Pickup the front of your bike, and carefully place it down so your stem is in alignment with the rest of your bike, and the fore / aft of the front Eflex is at the neutral point you marked
  • Now loosen the front left / right on the Eflex
This OCD procedure, in addition to making sure your bike is vertical, should ensure that the front of the E-Flex is aligned with the rear in a neutral position
If the measurement of the center leg is so important why the instructions should be worded different.
"Kickr should extend approx. 3.5” (90mm) from the front saddle. "
Don’t use the word approx, Say 90mm
The leaf spring is black on mine.
I don’t understand your directions for getting the wheel straight.
Align and straight in which direction? Easy to do straight up and down but the handlebars rotate too easily to know what is perfectly straight ahead. So if your handlebars are rotated slightly to the left and you put it down the bike will be asymmetric. Do I need to mark my bike so I know when its pointed straight ahead? Just a tiny rotation of the handlebars moves the saddle a nice amount in the rear so it seems like it would be very sensitive.
As to tipover, assuming you have the balance to ride a two wheel bike outdoors tipover shouldn’t be a problem for you. Well and lean that you can’t just mount the bike by stepping on the pedal close to you and only the handlebar close to you. A bit more work but not that hard
See my OCD alignment procedures, where I include a procedure for aligning the stem / front wheel
I bought one of these a few months ago. Have done plenty of long 4+ hr rides in Zwift using it, and really like the feel.
The point folks are making on alignment is that you can’t just line up the frames of the E-Flex, because that won’t align the front tire of the bicycle as if you’re going “straight”. You actually have to ignore the E-Flex frame alignment and actually line up the front tire (handlebar and stem included) as if you’re going “straight”. So connect everything, lift up the front of the bicycle (with E-Flex frame attached to it), align the stem to point dead ahead, then slowly set the front end of the bicycle (with E-Flex frame attached to it) back down on the ground. Most likely, the front and rear frames of the E-Flex will not align with each other (mine are probably 5-10 degrees out of alignment), but as long as your bicycle tires are aligned, you’ll be balanced.
yup, mine don’t align. Use handlebars to pick up and lower the front end. Results in proper alignment. For OCD reasons I have to ignore looking down at the front and rear frames :rofl:
Man, at first it really bothered me that those frames didn’t align (still does sometimes, if I’m honest). I thought I assembled it incorrectly.
Another check you can do is when you’re sitting neutral on the bike, check the alignment of the front dropouts with the front edge of the fork mounting plate. If that’s straight, you’re good.
Even if the $(&%^# front and rear frames are not aligned. :face_with_raised_eyebrow:
Not sure that it matters, but I believe you (and @dcrainmaker ) have the front fork stand backwards @Aaron. Check the photos on the InsideRide website and social media for reference. I’m basing my comment on that as well as my time riding it at the InsideRide HQ.
I mentioned that in my review (DCR’s being backwards). I actually think “backwards” is better since you can likely reach the lock knob while seated. Otherwise, there is no functional difference on the direction of the fork mount in use. Steering is still the same lock to lock and the fore-aft motion is unaffected.
why would you need to reach the lock knob? Its a bike and requires balance to mount and dismount :rofl:
Well, some could use the lock knob for mounting and dismounting. Or others might want to lock out the motion in use for any reason.
In reality, I removed my knob while making my other mods and don’t see the need for myself. But, it’s an existing feature on the rocker and could be used by anyone if they choose. So access within seated position might be a benefit for those that do.
I believe the knob is from the repurposed fork stand for InsideRide rollers. In that application, the knob serves a purpose and is closest to the rider as you describe @mcneese.chad (backwards). I’m with @bbarrera and never lock the front wheel. As I said though, I’m not sure it makes any difference, but I’m no engineer. I just noticed the difference and thought I’d share in the event there is a benefit.
FWIW, I like the open part of the fork stand facing the KICKR as I can store one of my Lasko fans there when I’m not riding.
Pretty sure I loosened the lock knob as soon as I got it and haven’t touched it since. The bike is plenty steady without it. Maybe the first time or 2 I rode it I was careful with mount/dismount after seeing Ray’s review video, but after a few months of using it I can’t imagine how I’d make it fall over or make myself fall off it.
