I was just wondering what peoples thoughts are if I were to install a press fit bottom bracket with my SRAM Force crankset.
My logic is that the way you install the crankset looks similar to the BB tool required. Obviously I wouldn’t want to damage any parts so any advice would be great.
Take a look at https://www.bbinfinite.com/. They have great products. I replaced my squeaky Specialized Roubaix bottom bracket with one from them and it’s been QUITE!!! and smooth. Give them a call or shoot them an email for options.
Do not use the cranks to press bearings into a frame! A bearing press contacts the outer race whereas the cranks will contact the inner race putting a high load along the axis of the bearings and potentially causing damage to the balls and the race.
Also, chances are that the crankset spindle wouldn’t even be long enough to make it through the un-pressed cups and bottom bracket of the frame in order for you to attempt this.
