Hi everyone, I designed this tablet holder as a pet project during the pandemic and I am quite happy with the result. I’d like to collect some feedback from other indoor cycling enthusiasts. Bottom line is : would you want to buy it if it was commercialized ?
you can install it without removing your garmin unit
I use it for my cellphone as well, if i am the one that has the TV. It’s overkill for a phone but allows you to use it without sweating on it and it stays in my field of vision.
That. is. amazing!
It even fits a large 13” iPad (most tablet holders don’t). And you have an AirPod Pro case holder!! If you put it on Kickstarter, I’ll preorder it the same day. I’m dead serious. The only thing I’d add is a second cradle for snacks per default.
There is two sizes of clamps to accommodate MTB bars or thicker bar tape and the surface is quite smooth. A rubbery finish could be an upgrade idea, but right now the option would be either a layer of bar tape or simply a turn of electric tape.
Probably you’d want to do a v2.0 after sending out the first batch. I bought a pair of cycling shoes designed by a podiatrist in Australia. The fit is spectacularly good (I have wide feet), but there were quite a few v1.0 bugs to work out. A lot of them are just things like “rotate the dial by a few degrees” or “use a slightly different material here”.
Without scaling up anything, the first batch could be sold at 70-75 USD, shipped.
Edit : there could be an option to send the device partly or completely dissassembled, which would reduce drastically the shipping AND the unit cost (between 15 and 25 dollars)
