KICKR CORE Zwift One+ Trainer Road?
Does the KICKR CORE Zwift One work with Trainer Road?
Thanks in advance.
No reason it shouldn’t. Kickr Core has all the standard Bluetooth and Ant+ protocols so it can be controlled by TR, Zwift, Rouvy, or any other app / program.
However, if it only comes with the Zwift Cog and not a full cassette, then you can only use erg mode if you’re only using TR. Resistance mode in TR requires you to shift and / or adjust cadence to meet the power targets.
Lots of good info on how to run TR and Zwift simultaneously at the links below.
You can of course always get a cassette (and freehub), the original core never came with a cassette either, just a shimano 11s freehub
Yes. I’ve used it without any issues.
