Latex tube // 64mm rim // removable core
Quick question…
Am looking to run latex tubes on a set of 55mm and 64mm rims.
I have just bought a set of Quarq TyreWiz doo-hickeys because technology and they require the valve cores to be removed.
My existing method of using valve extenders will not work with shorter valve lengths as the TyreWiz fouls the rim…and they can’t be screwed into valve extenders.
And no latex tubes I have found are long enough.
Any ideas?
Silca makes valve extenders that are compatible with removable valve cores here: https://silca.cc/collections/accessories/products/threaded-valve-extenders-with-speedshield
