Let’s see some Tri/TT rigs
Same height, just got fitted and he brought the saddle super high, like 840 mm. Like it so far.
What size is your frame? It looks a little smaller than mine.
It’s an XL
And they’re a nuisance! Took on one of the local ranges and had that reaffirming knowledge I had the salvation of that sweet 28 tooth … nope! Every time I switched into it the chain just skipped and went back to my previous gear. Had no idea what it was but I had to power up these ranges without my easiest gear. Must’ve went over a rough bump on the way out there but when I rendezvoused at the bottom I saw the spoke protector had wiggled it’s way loose. Cut it off then and there
Nice matchy matchy with the bar tape to the frame accents!
FB_IMG_1559040773148
My recently completed Shiv in training mode (heavy PowerTap wheels, Gatorskins, saddle bag, rear flasher).
I need to get some pics in race mode with the BTA (ditch the seat tube bottle), race wheels (Bontrager Aeolus 5 Comp wheels with R3 25c tires), power pedals (PowerTap P1).
You need to show up to your next ‘C’ race with your training setup. Such a beautiful bike with such ugly wheels :slight_smile: You’ll turn some heads for sure.
LOL, it’s a bit of a dog for sure with that setup. Still rides well despite the porky weight and un-aero.
But the feel (and look) is much better with the race setup for sure :smiley:
What rear light is that Chad? Specifically the aero seat post clamp .
The 2nd generation Bontrager Flare R. I have a few and use one for every ride outside.
I used the stock reflector mount from Specialized. I found a reflector that had the slip-on mount, and used the threaded brass nut in the light mount through the reflector bracket. Partly bodged, but works well.
Edit to add a stock pic (from a Trek Speed Concept version, but the Shiv one is similar) of the main mount:
Pics in race mode.
It ripped on the Duathlon course today.
(fastest bike leg of the day)
Not the best bike photos but you get the idea - slowly getting position dialled in :+1:
what is the aerobar set up? I have a P3 and want to change up my aero bars a bit like yours.
This was the first time out with the flo wheels. Definitely faster with them
I posted this in the alluminati thread but I should probably post in my Caad10 Franken-TT bike here.
Zipp Stealth basebar, 50° USE extensions angled down to 45° with backstopped and wedged Wattshop cups. Went with this high hands set up to accommodate an injured shoulder, (T-boned a car when it pulled out in front of me at 45km/h). Since gone back to lower hands. The high hands, while great head on, seemed to siphoned speed off when the yaw opened up.
Thanks. Ever since I saw Lucy Charles setup and IM Kona Ive been intrigued.
I often feel I need a bit maybe 15% incline in my bars to make me more comfortable
15% on the forearms is good, sort of the tipping point.
Position has been changing over the season. This is where it’s at just now but still a bit hunched in the back… Power is within 3% of road bike now which is okay I think.
