Thanks.
I have played around with my mix and do one part table sugar, 1 part dextrose, 1 part gatorade and then some salt This cuts my cost a bit (table sugar is cheap) and I don’t have any stomach complaints.
and mixed it with 60g of Gatorade mix+salt. It’s worked well but this Maltodextrin has been super hard to mix. Anyone have a suggestion for a specific Malto powder that mixes better?
I have to use hot water to mix high concentration of Malto. I just run the coffee maker into a shaker bottle with the 2:1 mix in it and then shake it while it’s super hot (note: it expands and will spray a bit, so be careful when you pop the lid open).
30g of mix in a 24oz bottle is high concentration? I think if i gotta go to that trouble i’ll just keep spending money on mix.
I put 60g of Maltodextrine and 30g of Fructose in a 21oz bottle.
Having said that, you asked how to mix maltodextrine. The answer is hot water. I don’t see that as “going to that much trouble”.
I asked if there was one that mixed better. Not how to mix this one.
Regardless of the name, it’s maltodextrin. They all mix the same.
Maltodextrin is somewhat difficult to mix because it is such a fine powder. I fill my water bottle half way with warm water, add my ingredients (malto, fructose, electrolyte, and BCAAs), shake vigorously, then top off with cold water a few ice cubes.
There are other sources of carbs that may mix easier such as dextrose but you need to consider different transport mechanisms if you’re trying to hit 90+ g/hour.
My custom mix from Infinit Nutrition uses maltodextrin, dextrose, and pure cane sugar, and mixes very easily in cold water. It is more granular like Gatorade powder, whereas SiS Beta Fuel is more powder-like similar to maltodextrin.
The articles below may help your search.
I have the same one, it definitely mixes better in warmer weather/water. I suspect any type of malto is going to have the same problem though.
my vitamix makes for a VERY expensive maltodextrin mixer. I put the water in, turn on low setting so there is a small vortex and mix in powder. It does a good job but its complete overkill.
I use a blender ball in my bike bottles for my corn starch. It’s a little rattly when the bottle is empty, but it seems to help get things mixed better.
I know there are several fuel threads now, and I’m pretty sure this has been covered, but I can’t seem to find it…
I totally get the 2:1 ratio for Malto:Fructose if you’re trying to maximize fueling. But I thought I read at one point that replacing the Malto portion with 50:50 mix of Malto:Dextrose has some advantages as well. Something to do with differing rates of metabolizing them? Aside from the taste/sweetness, are there pros cons to using a 50:50 Malto Dextrose blend in place of the Malto? (So in theory you could end up with 1:1:1 Malto:Dextrose:Fructose?)
They are both glucose molecules though at the end of the day so what are you hoping to achieve by this?
Well that’s my question. I thought I had read that there are benefits to a 50-50 mix of Malto and Dextrose, but wanted to understand what those benefits could be.
from what I understand, and i am not an expert on this by any means just through my own reading, the difference is the speed at which your body can absorb the two.
dextrose is a single sugar (glucose molecule) while maltodextrin is a compound of multiple glucose molecules. Because dextrose is a single sugar the body can break it down and absorb quicker than maltodextrin. The issue though is you get the insulin spike this with that is somewhat tempered with maltodextrin.
That’s where my knowledge basically ends.
From Wikipedia: Maltodextrin is typically composed of a mixture of chains that vary from three to 17 glucose units long.
Maltodextrins are classified by DE (dextrose equivalent) and have a DE between 3 and 20. The higher the DE value, the shorter the glucose chains, the higher the sweetness, the higher the solubility, and the lower heat resistance.
I’ve emailed the shop where I got my maltodextrin to see if they can tell me the DE of what I purchased. This would be one data point as a start.
I read it on the Internet so it must be true … Searching “maltodextrin vs dextrose vs fructose” turned up a wealth of information.
A good description of basic types of sugars we could use in our self-made mixes.
I like infographics that are easy to understand. The articles are good, too.
Now I’ll profess to not having read the above links that @rkoswald has posted, but my understanding of why dextrose can be beneficial in a mix over just malto is to do with osmolality. I’m not a chemist, nor a nutritional expert in any way, but from what I’ve read this is my understanding.
Our gastric osmolality is 280-330 mOsm/kg.
A common misconception is that malto is used in lieu of dextrose because it is slower release, but this isn’t the case. It is used as it has a lower osmolality.
So what does that mean and what’s the benefit?
If you put 60g of dextrose in 500ml of water the osmolality is 666mOsm/kg. Because it’s twice as concentrated (hypertonic) as the osmolality of the stomach it massively slows gastric emptying. The body has to work hard to throw water at it to dilute the content of the stomach before passing it on to the duodenum (the next stage and where carb absorption occurs).
Conversely, 60g of malto in 500ml of water, assuming a ‘dextrose equivalent’ of 12, would have an osmolality of 86 mOsm/kg. This is now hypotonic. I don’t believe this slows gastric emptying but I think the osmotic pressure will draw minerals from the body into the fluid increasing its osmolality at this stage.
So by balancing the correct amount of malto, dextrose, fructose and electrolyte we’re trying to hit an isotonic osmolality to speed up gastric emptying and get as much of the drink into the duodenum and start the absorption of carbohydrates into the blood.
I’ve not checked any of the recipes above, and clearly they’ve worked for those who’ve been using them, but I haven’t seen anyone checking to see if the osmolality stacks up. They may well not be causing GI issues, but that doesn’t mean they’re optimal.
This is where I’m interested and intrigued by Maurten/Beta Fuel. Perhaps it’s clever marketing, but everyone’s been making 2:1 for a long time. What’s special about these two? Are they just using a low DE (lower the number the lower the osmolality for the same grams of carbs) maltodextrin to get the high volume of carbs past the stomach and into the gut quickly? But at this point it’s then just a cluster bomb of glucose waiting to go off. Amylase rapidly slices up the matlo in the gut, osmolality flies up and you’re back to the same problem???
I dunno, but I’m convinced they’re doing something else with it…
Well and to add to the mess, what happens when you use clusterdextrin rather than malto or just dextrose?
