I’m ordering a Mosaic GT-1 45 this week and need to decide on the component choices within the next few weeks.
This is going to be my gravel/trainer/mild road bike, to replace my 2021 lower tiered diverge. I had my fit last week and looking forward to my significantly more aggressive geometry. Living in the gulf coast, my riding is typically inside on the trainer with a long outside ride every other weekend (around 60-70 miles). Will be outside a little more as it cools down. And some casual evening rides pulling my 3 year old in her trailer.
The main goal will be gravel racing, but I’ll also be doing some general group paved rides.
I’m going with the new SRAM Red XPLR 13 spd. What I’m unsure of is what size front chainring I should go with. My Diverge has: a 46/30 up front and 11-34:11-13-15-17-19-21-23-25-27-30-34 in the rear.
The SRAM 13 speed has the following sprocket sizes: * 10,11,12,13,15,17,19,21,24,28,32, 38,46T
On my typical weekend rides, I never leave the 46 tooth front sprocket and when it’s flat, usually hop between the 17 and 19, but also can vary a bit based on the hills. That’ll be similar to if I have a 42 front chain ring and stay between the 15 and 17.
I used the following chart which is largely supporting my decision for the 42. I hesitate to go much bigger as it’ll be me higher into the cassette where the jumps get larger, but I’m admittedly pretty uninformed on the topic. I do plan some larger gravel races next year (mid south, gravel locos, etc) and probably one mountainous Colorado race, so have also considered getting 2 sizes, like a 40 & 46/48. Just not sure if necessary.
Thanks for any input -
