Outside workouts on Edge 810
I’ve used TR’s outside workout feature a few times now on my Edge 520, and the pairing/execution seems pretty seamless. My wife would like to do the same with her Edge 810, and I cannot find the workouts anywhere on the device, no matter how many times I pair, sync and update.
On my 520, I find the scheduled workout under the ‘Calendar’ option, not under the ‘Workouts’ option. On her 810, there is no Calendar option, and the workout does not show up under the Workout option.
If there is anyone using the 810 with outside workouts, where should they show up on the 810 unit? What am I missing?
From Garmin help..
Starting a Workout
  1. From the home screen, select > Workouts.
  2. Select a workout.
  3. Select Do Workout.
After you begin a workout, the device displays each step of the workout, the target (if any), and current workout data. An audible alarm sounds when you are about to finish a workout step. A message appears, counting down the time or distance until a new step begins.
+1
I use outdoor workouts on my 810 and this is exactly what I do; maybe reauthorise Garmin / TR?
