Aside from the general chat about strength training, core work, and weights, I wanted to focus on this specific issue.
Because ultimately, when I’m on the bike, the one obvious issue I have is that I’m unable to hold myself in an aero position for long without my triceps really starting to burn.
So I’m interested in hearing from people who’ve had this problem and overcome it, and whether it was through…
- “on the bike” training, i.e. just holding the position for longer and longer each ride until it stops being painful
- specific off-the-bike tricep exercises
- off-the-bike exercises but aimed at more general arm strength or even just core stability.
My advice would be to incorporate some general upper body and core strength training. IMO if you just target your triceps you’ll likely end up with some muscle imbalances. Just targeting triceps could create problems with your shoulders and back.
I second Skiandbike4life’s recommendation about some general strength conditioning. Close grip push-ups puts some decent load on the triceps opposed to the conventional wider grip which primarily work the pecs. Btw the push-up is basically planks bigger cousin
hence good core-work.
Interesting topic as have the same issue however can’t really be down to tricep weakness as being a swimmer as well as a cyclist I have quite well developed triceps. Keen to know how you resolved the issue.
As someone who transitioned to cycling from being a gym-goer, tricep weakness has never been an issue until I dislocated my shoulder and had 12-14 weeks out from upper body training. Now my triceps fatigue quickly and I struggle to hold the aero position again.
Solution = Train those arms!
