Possible to import TrainingPeaks PLANS into TrainerRoad?
I have a purchased plan from TrainingPeaks that I’d like to integrate into TrainerRoad, and use both. However, I’ve noticed that workouts that are on my TrainingPeaks calendar that are from the purchased plan will not show up on my TrainerRoad calendar. If I manually build a workout in TrainingPeaks, it will sync to TrainerRoad. But the workouts from the purchased plan will not.
Has anyone found a workaround for this?
I’m guessing TrainingPeaks has restricted that import on their end so people aren’t importing purchased plans out of the platform, much how TrainerRoad doesn’t let you export workouts of their own platform.
Not sure these cover your needs, but there are two support articles that might help:
Yeah, I’ve been through those. If I build my own workout in TP for a certain day, it will sync. But the workouts that came through a plan do not. Very strange considering you can do the TP workouts from a coach/plan in Zwift…
Are the Workouts in your TrainingPeaks Training Plan built using “Duration, % Functional Threshold Power, and Target”?
To complete TrainingPeaks Workouts in TrainerRoad, they have to be created in a specific way in TrainingPeaks. Check out this section of the artice for more information: How to Build Custom Workouts in TrainingPeaks for TrainerRoad
Likewise, are the Workouts scheduled to be completed in the next two days?
Custom Workouts from Training Peaks will only sync if they are scheduled within two days of the current day.
If you are working with a coach, you could ask them to build your Workouts following the parameters outlined above. That will allow them to sync over! Let me know if you have questions!
It sounds like you have built the Workouts using “Duration, % Functional Threshold Power, and Target”?
This solved it!! Thank you, Sarah. I did not know that TR only pulled workouts in the upcoming two days. I copy and pasted a few of the workouts to the next few days and it worked. Thank you thank you
YAAAY! I’m glad that did the trick! You’re very welcome :heart_hands:
