use liquid chalk instead, way less messy and actually stays where it needs to be (your hands)
Liquid chalk contains resin, which builds up on things, almost impossible to wash off, and makes them nearly impossible slippery for anyone else not using rosin products.
A climbing bucket is the best idea.
I store mine in a tupperware container. A climbing bag might be better but the tupperware has worked pretty well for the past couple years.
Thank Iâll check it out. The 24 sets is over the course of a week, bot a day though.
Yes, thatâs what I thought.
24 hard sets for quads (even if itâs all leg press and leg extensions) over a week is still A LOT of work ⌠especially if youâre old and crusty.
I should add that is 24 sets for both squats and leg press, so 48 sets total.
Iâm also pretty old and crustyâŚ
Foly huck! That seems ⌠borderline insane. Unless the sets are massively submaximal, in which case whatâs the point?
If I remember correctly from their podcastâŚit would be somewhere around 65% of a max 1 rep lift.
I have no idea if this is a lot or a littleâŚmy experience with weight training minimal
Iâm gonna give it a shot starting next week thoughâŚkâll let you know how it goes
Thatâs a weight you can do about 15 or 16 reps with. Pretty light, but a sensible place to start from if you want to ease into lifting.
Hmm ok so these sets would be 10 reps per set. So this doesnt seem to unreasonable.
SoâŚi went to the gym this previous winter for all of 1 month. I was squatting 185 5 timesâŚIâd probably just round up and call my 1 rep max like 200. So iâd be doing 6
Sets of about 130lbs, 10 reps each.
Why do you think youâve chosen to focus on volume over intensity or quality?
Well, ifâs not so much âchoosingâ anything as contemplating following a plan. So this is a 2 week what they call hypertrophy phaseâŚwhere I guess the goal is to put on muscle. Reps and sets go down and weight goes up in the next phase, with the goal being to build strength.
Abe_Froman,
Please ignore the idea of 65% of 1 RM for hypertrophy. Itâs nonsense. If you have not squatted in a while you will need some time to regain the coordination and motor learning, as well as getting your back used to the work.
Once youâve done that, letâs use your data as a starting point: 5 reps at 185, now ask yourself this question: I can do X sets of 5 reps at 185, but is that all I can do at 185? In other words, you know you can do 5 reps, but can you do 6 reps? 8 reps? Maybe you can do 10 reps but you never actually tried.
So, letâs now assume that, in fact, for X sets of 5 reps, 185 is legitimately the weight you should use to be within 1 or 2 reps of actual failure. Take 5 pounds off each side of the barbell (10 pounds total) - how many reps can you do for those X reps? Lift it. Letâs say it is 7. Then remove another 5 pounds from each side (20 pounds total from the 185, so now 165), how many can you do? Letâs say it is 10. Youâre at 82.5% of your max 200 weight. People underestimate how much they can lift, especially with legs, because itâs very uncomfortable, but the reality is that you can do far more than the nonsensical 65% number that is thrown around like gospel.
The ideal way to increase reps is to slightly reduce the weight you lift while incrementally and methodically increasing the reps until you find the sweet spot for that rep range.
Well, hereâs my issue with that thoughâŚis that the best way to go about finding the best weight to lift for the plan Iâm looking at to start monday?
AgainâŚitâs 6 sets of 10 reps, 4 days a week. I assume i should not be attempting like a 10 rep max weight for each exerciseâŚ
I will look at that plan and get back to you. Iâm suspicious though - hitting a particular muscle group four times a week seems like youâre dealing with one of two extremes: 1) wasting your time because youâre not using sufficient weight or 2) asking for an overuse injury.
You mean this: Basically a 3 week ramp up phase, then followed by 2 weeks of FOUR workout a week, 6 sets of 10 reps. So basically 240 squats a week. It then afterwards goings to less frequency, heavier weight, lower volume of sets.
In order to do that amount of volume without getting injured you would need to use fairly low weight, and you really are not going to gain much of anything from that. Hypertrophy isnât simply volume, it is volume in conjunction with the appropriate amount of weight, and I define that as weight sufficient for your rep range to be 1 or 2 reps short of failure.
Personally I would not do this workout at all. However, I am not you, and if you are dead set on doing it thatâs your choice. I think a possible approach would be to find your max weight for 6 set of 10 reps (1-2 reps short of failure) then knock 10 or 15 pounds off that amount.
Also keep in mind range of motion. Plenty of people squat without using full ROM, which means they can use more weight than they otherwise would, and I guess thatâs good for ego training. 6 sets is a lot, and youâll likely get tired toward the later sets, which means youâll start half-assing your range of motion, so consider reading my post on strength training for max pedaling power - I discuss using the safety arms as part of your squat to make sure you go to full ROM and donât cheat yourself.
Without looking into the program.
As a beginner I would start with 2 days a week of 1-3 sets per movement. Then gauge if you want to add another day or additional sets. Also find a weight thatâs challenging for the 10 reps where you could do 3 more reps if you needed too.
Believe me I am not married to any strength training approach. Quite the opposite. Iâve lifted weightsâŚand actually had a personal trainer (wife of cycling team leader) last year check my squat form just to make sure I wasnt botching anything. But Iâve never lifted long enough to see any noticeable increase in strength.
The fastcat plan appealed to me in that it seems primarily structured around the assumption that Iâd be hitting weights hard while mostly off the bike in the off season, which is where I am right nowâŚ
Go on, Iâm going to bite. Explain the fuckery that underpins you dictating to a beginner to squat ass to grass for power output on a bike.
What are you riding, a BMX with your knees around your ears?
This is more or less the approach that Iâve taken. Just finishing up a kind of 3 week ramp up phaseâŚwhere I started liftingâŚrelatively lightâŚgot through some initial DOMS, and increased weight to the point where itâs challenging for 10 reps but I could definitely do at least a couple more. Everything feels heavy, and challenging, but not scarily so. 3 sets, 3 times this past week has definitely felt like work, but not excessive at all.
The plan is to effectively double volume this coming week, plus going to 4 days vs 3. If I get 3-4 sets in on the second workout in back to back days and it seems easy still Iâll add on some weight. I have a feeling that doing my current weight squatâŚsquat of 135, for 240 reps on a week will be plenty honestly.
Itâs only 2 weeks thoughâŚI can gut that out.
