I’m looking to warm up on my Kickr at upcoming races but have no idea what I need to power it. Can anyone who’s done this point me in the right direction please?
TIA Andy
I have used mine of late. I have a Ford Ranger which has a 240v outlet in the back. SO I just plug in and away you go. It draws almost no amps so could easy be run of a 12v outlet (old school cigarette lighter socket) with a cheap inverter
due to power issues in my garage, I used one of these daily (and sometimes twice) for about 2 years, can run a turbo and fan for over a year
Couldn’t get the car close enough ![]()
PS it’s basically a moped battery with a cheap inverted … under the top left flap is a three prong uk plug inverter
Thanks guys
Just bought this, should do the job
I’m surprised that nobody linked to DC Rainmakers article on Team Sky’s battery powered Kickers. Here it is as a reference: Wahoo Fitness sponsoring Team Sky
BACK FROM THE DEAD
Does anyway have a good way to do this?
The 12v inverter is probably the easiest but should I be worried about draining my car battery if it’s not running? Just for like a 20-30ish min warm up.
Or is there a cheap battery/inverter that might be safer that isn’t like $500?
I have no first hand experience, and do not know exactly how much power the kickr draws when running but…
I would not be surprised if something like this would be able to run it for atleast 2-3 hours.
and it seems like the iGen200s model with a good deal more batt capacity is only a few dollars more expensive at the moment.
A quick google shows that the kickr power brick has a max draw of 60w, so with a 200 watt hour batt pack, you’d get a 2-3 hours at a minimum (accounting for inefficiency of power conversion etc)
Sweet thanks! Yeah it doesn’t pull much power but if I tried to do this I would probably go the additional battery route just for peace of mind.
I was at race over the weekend, and someone had a RYOBI power inverter running their Kickr core for warmup. Small enough to fit in a backpack.
RYOBI 150-Watt Power Inverter for ONE+ 18V Battery (Tool Only) RYi150BG (homedepot.com)
