Ok, so I currently ride an Canyon Endurace CF SL 8.0 Aero in Size S, but with a 100mm stem instead of the stock 90mm stem (canyon fucked up and sent the bike with the wrong cockpit, but I think it worked out ok). I feel really good on the bike, but I want something just slightly more agressive. Reach is OK as I have it, but I feel that I could be a bit lower in the front (stem is already fully slammed). Unfortunately I have pretty long legs and a short torso, but long arms.
Here’s a short video of me on my bike in non-aero position:
Here are my measurements:
Inseam: 83,5cm
Wingspan: 179cm
My bike has these measurements:
Size: S (ca. 54)
Reach: 376mm (+100mm stem)
Stack: 557mm
Crank Length: 170mm
Saddle heigth: 73cm (measured from center bottom bracket)
Saddle to bar drop: ca. 8cm
The Endurace already has a pretty agressive geo for endurance bikes, but I still want something a bit lower, but not longer (switchting to 90mm stem is OK).
Currently I’m thinking about the Cannondale Supersix EVO in size 51. It’s 23mm lower in the front and 2mm longer. If I switched to a 90mm stem, that would make it 8mm shorter.
Could this work or are there any other bikes I could consider? Unfortunately going one size smaller with the Endurace is not an option as it is only available with 650b wheels.
