Proper TrainerRoad and Zwift integration [Feature Request]
It might be due to running both at the same time and using ANT to connect with Z, and BT to connect with TR. I have a long USB cable that runs from my computer all the way down to where the ANT sensors are on the trainer, so in theory it should be a strong connection. But I’ve had at least 3 episodes in the last year where the ANT connection to Z completely drops and will not come back.
Zwift dropouts are known and ongoing issue…it has improved recently, but can definitely still occur.
IME, the best connection is usually through the AppleTV app, followed by an Apple mobile device…with the worst usually being a PC.
But, as always, YMMV…
Yes known issue for those using both like I do too and BT on TR with ant+ on Z.
Ant+ also has some bad moments if I pick that connectuion in TR so for me is more an ant+ issue overall than a Z or any platform issue.
I use ant+ for TrainerRoad and Bluetooth for Zwift… and it’s only Zwift that ever drops :man_shrugging:t2:
Not trying to be rude here, but you just said you don’t experience serious drops with Zwift.
Yes I did and thats correct. Im not saying
Z hasnt connection problems but serious for me is loosing power for more than a couple of seconds having to bail out of the ride and reset the app etc. My power drops are never like that and no more than once in the same activity from time to time not every activity has those kind of drops. That for me is a minor issue not a big deal.
Even those are only felt on ant+ at least so far.
About Z drops. Today after 3h40 in my Z ride (doing the uber pretzel) I had 3 consecutive drops. First two only for a sec and the third a bit longer but nothing problematic. The good thing is that if id ride only a couple of hours I hadnt experienced those drops :grin:
Would this work on Edge which someone said is based on Chrome?
Works fine for me using edge :+1:
No news yet? Now we really are close to the end of January :laughing:
Its very disappointing. Looks like they’ve misjudged a release date yet again. I wish Nate would just stop giving dates out.
I connect Zwift to my PC using an ANT+ dongle and have never had dropouts… I think I maybe used to occasionally using BT, but I can’t remember now.
I don’t even use Zwift, but the time this is taking doesn’t reflect very well on TRs capabilities.
Agreed. And theres been absolutely zero sign of either Nate or Jonathan on here for some time now.
Just out of curiosity, and without throwing fuel on the flames, but…. How many of you on here are software engineers? I am, and know all too well how difficult some of these things can be. It is easy to say, just add a button that sends the workout to Zwift and then monitor Zwift for completed rides to see if it was the workout. Sounds easy, but I bet you it isn’t. I’ve not looked at the Zwift API’s to see just how easy it is, so I’m just guessing it’s more difficult than people think
Yes, radio silence is annoying but I’m sure they’ll tell us when they have something to report
sure, but when one man operations like David with intervals.icu already have the integration active on their platforms, it does raise some questions
@hubcyclist One difference is that intervals.icu isn’t sending its own IP to another platform.
last i checked, workouts aren’t really IP lol if they’re afraid zwift are gonna try to reverse engineer their ML maybe that’s another matter but nothing is inherently special about individual workouts
Sure, but it’s easier to drop what you’re doing to work on this when you’re a one-man operation. A bigger company with a bigger team that already has work in progress for a pre-existing roadmap is harder to pivot to work on this, not to mention that TR is a paid product with a vocal user base that would be rightfully upset if rushing things out broke things for them (something for which intervals.icu would likely be given lots more leeway because it’s a one-man operation), and has a huge workout library and apps on multiple platforms, so the QA effort is probably considerable.
While I was using intervals.icu this month to push exported TR workouts to zwift, I was pondering why the “strava API issue” didnt cause a pivot to Trainer Road moving to a intervals sync. A TR/Intervals sync would have solved strava, possibly even Wahoo, with a single blow, and avoided using the zwift API directly for initial capability rollout. A more polished direct zwift api integration could then be pushed to a later date. Only my thoughts, but here they are shared. I have no doubt that I’m certainly missing a number of important points that would not have made this a possible resolution, but I can’t stop myself from posting!
