Hi,
Does anyone know if it is possible to run a quarq dfour with sora 3000 9 speed chainrings?
I’m using shimano 5 bolt rings on my quarq dzero, if that helps. If it bolts fit, it should work.
and this? PM-D4-SPDR-D1 | SRAM
They both use Shimano’s 110asy bolt pattern
Should you need to change something an cant find a part - You can also run a 10/11 speed chainring with your 9sp setup. You should also be ok running a 10sp chain with the 10/11sp ring as well.
Also this company is having a going out of biz sale (30% off?/). These should work with your Sora Crank
https://www.clevertraining.com/stages-cycling-ultegra-r8000-power-meter
https://www.clevertraining.com/4iiii-precision-power-meter-shimano-ultegra-r8000
https://www.clevertraining.com/4iiii-podium-precision-powermeter-shimano-105-7000
https://www.clevertraining.com/4iiii-precision-power-meter-shimano-105-r7000
