Thanks for bearing with me while I looked into this @DanF!
First off, returning to triathlon will naturally cause a significant increase in training stress- you’re juggling 3 sports as opposed to 1! With that said, there is only so much stress you can productively add, regardless of where that stress comes from. It may just take some time to adapt to that and settle in.
My next thought - are you following the Training Plan exactly as prescribed?
I’m seeing quite a lot of extra activities.
This is not a problem per se (we want you to do what you enjoy too!), but the training stress does add up and something has got to give.
Either your workouts are adjusted by RLGL orrrr you accumulate an unproductive level of fatigue
If I look further down your Calendar, it looks like it was the latter?
I can see an annotation on the 8th and 9th of May that says you were sick/ feeling tired. Perhaps that might not have happened if you had accepted the adaptations? It’s hard to know.
While the cause of sickness can be out of our control, it is very often a consequence of doing too much, getting run down and therefore unable to fight the bug.
During the week that you were sick, your TSS decreased by more than half. RLGL will use that information to determine how much training stress you can handle moving forward.
My suggestion for you moving forward?
Accept the adaptations from RLGL. Let yourself settle into a consistent training rhythm. You will progressively be able to handle more training stress without interruptions from sickness or injury. Be patient until you get there.
If you feel like you would like your progression to be more aggressive, adjust the settings as I described above, as opposed to ignoring the adaptations. Remember, this has been designed to make you faster!
I hope this helps! Let us know if you have any other questions!
