Trying to find the Rockr Pod Lite or similar in the UK ($75 shipping to the UK from the US!).
Any suggestions?
Failing that it doesn’t look too hard to make one but I guess the compound curve on the bottom is the tricky bit. Any thoughts on how to generate that curve?
Many thanks,
Dave
For starters, here is the list of rocker makers I have within the UK region:
Additionally, if you are explicitly searching for a rib style rocker, the one I can think of that might be a closer reach for you is the following.
I may be able to help you find other options if I know more about your budget and goals for a rocker.
