Sealant remover/cleaner?
Does anyone know of an easy cheap sealant remover? Effetto Mariposa make some and it works well but it’s rather expensive and hard to get. I am thinking that there should be some generic solvents that would work just as well?
Three things that have worked best for me.
Pressure Washer
Abrasive Cleaning Stick - Amazon.com
Rubber Palmed Gloves - Amazon.com
With the Abrasive Cleaning Stick / Rubber Eraser working better than the gloves. Takes maybe 10 minutes per tire when dry.
Like the abrasive cleaning stick I have been using rubber cement erasers, it has to be dry though if it is wet just smears it.
https://www.amazon.com/gp/product/B08P7J4GW7/
I need something to remove the stain from my bike and clothes
Clothes - no idea.
Bike - I’d try something like Goo Gone followed by a cleanup with isopropyl rubbing alcohol. You could try the goo-gone recommendation on clothes too, but spot test it first.
The Silca Ultimate Sealant Remover works like a charm, though it (like most things Silca) ain’t exactly cheap. That said, it provides excellent bang for your bucks.
Dynamic has one:
I have not used any cleaner products with my wheels, as I use Orange Seal.
