I’ve been scratching my head using my Stages. Power seemed way low. Up until now I only had a Tacx Vortex trainer to use as a power meter. I can accept that the Tacx isn’t the most accurate power meter. Riding side by side with a friend who has a Stages we were calling out power numbers. I was consistently 20-30 watts below him.
I contacted Stages and they suggested a full factory reset which means taking the battery out and then shorting the terminals inside the unit for 20 seconds. I had previously taken the battery out but that wasn’t enough. Before I did this I wanted to do some testings.
This was the Stages versus the Tacx. As you can see, a solid 50 watts off at 325 watts. The interesting thing with this chart is that they drifted farther apart towards the end of the test. At 200 watts the stages was within 10 watts at the beginning and then was 25 watts off at the end.
Second test was Tacx vs Stages vs Powertap hub. Stages vs Tacx is still 44 watts off at 330 watts. This one also seems to show the gap widening between the beginning of the test and the end of the test. At the beginning, it’s 295 watts vs. 285. At the end, Tacx 225 watts vs 197 Stages (28 watt difference).
Also, the Powertap consistently reads higher than the Stages. Now at least, I figure that my Tacx reads way high especially as it’s fully warmed up. But my Stages is still low across the board.
Here is my third test. Before this test I did the factory reset on the Stages power meter. Now the tables have turned on the Powertap hub. The Stages wattage is up and beats the Powertap at almost every wattage.
My Tacx is still way high - especially at higher wattages. At least I have two other power meters now that mostly agree.
I used Golden Cheetah to read the power files and then copied the data into Excel to make charts. It’s a big of a hack and took me some time to figure out and I’m already pretty good with Excel. Dcrainmaker’s tool for $30/year is probably worth it if one was going to do this a lot. Zwift supposedly has some software that will compare two files.
BTW, I bought a new Garmin so now that I have two - I can record each power meter simultaneously. For the Tacx, I recorded the session with their app which then saves the workout to the Tacx cloud.
Dcrainmaker’s tool will do time shifting to align the power better. I just hit the start button on each device simultaneously (as best I could) and it was good enough. One could shift data by some seconds in Excel manually. It wouldn’t be hard.
Here’s a question for people that know Stages power meters. Why would the factory hard reset make such a difference? It just seems strange that having the battery out would not be enough but shorting the terminals would provide some level of magic.
My Stages is a Campagnolo gen 2. One thing that occurred to me was that I didn’t install mine with a torque wrench. Stages lists specific torque settings for Shimano/Sram. I’m wondering if the torque setting on the crankset would make much of a difference, especially for Campagnolo. I mean, it doesn’t seem like the torque on the hirth joint on an Ultra Torque crankset would make much difference to the Stages power meter but it’s something I could check and then retest.
I’m not sure turning it around will do it. Here is the way Stages supported suggested I do it (shorting those inner terminals with the edge of the coin battery):
The other issue I have with this stages is constant dropouts. I’m not sure yet if it is my old Garmin 510 or the Stages itself. I have a new 530 which I will try with the Stages out on the road
Did you have to do anything after the reset, or just zero-offset as normal?
Regarding the dropouts - mine mostly gets dropouts when the battery is nearly empty. I found buying good quality batteries makes a difference. I also wrap electrical tape tight around it, mostly because any sort of water ingress drains the battery within days, but it might help keeping it tighter too. I’ve heard of others bulking up the battery with a bit of paper or cardboard for a tighter fit.
I had a couple of dropouts yesterday with my Wahoo Bolt head unit. Also, the battery I just put in a few weeks ago is already showing lower (in the TR app anyway)
My battery is a brand new energizer. Regarding waterproofing. Mine has never been ridden in bad weather but one thing I was thinking was that the gasket should really get some silicone grease like they put on watch case gaskets. My gasket came dry.
yes it will, because the entire top of the case is the + terminal. Turning over the battery will short circuit those two contact points inside the power meter (or any device that uses that type of battery).
I’m guessing here, but I wonder if it could have been storing a previous torque value and not correctly zeroing the torque every time you perform a zero offset.
