Whenever I do a trainnerroad workout I seem to have problems sustaining the right amount of power even though I maintain my cadance or even increase it.
I have set my trainerroad app on ERG mode so I don’t seem to understand why I’m always beneath to power treshold.
It’s not because I can’t handle the power level that is suggested.
Can anyone help me out ?
I suspect the issue is that you haven’t figured out ERG yet. Do not pay attention to the power target, just pedal at a consistent cadence. It takes a bit of a leap of faith, but the issue is you are modulating your power trying to hit the target at the same time ERG is adjusting and you end up chasing your tail. Just pedal at a consistent 90 RPMs or whatever is comfortable and don’t look at power target.
His cadence actually looks pretty good to me, at least based upon the minimal info we can gather from the screenshot. There is a very slight increase over the course of the full interval, but it’s far less than the problematic cadence variation we sometimes see.
This might be worth sending to support@trainerroad.com so they can review the logs deeper. It may be a trainer related issue.
I will say that the final interval is quite odd looking, and seems to show that shifting was used to hit the power spike while the cadence actually decreased with respect to earlier in that interval.
That minimal increase should not be a problem IMO. Some amount of fluctuation is normal, and a proper trainer setup should be able to handle that steady increase with no real issue.
There seems to be something just a little off there, but I don’t know what, since your cadence seems fine from what I see.
I’m going to ask the really dumb / obvious questions:
are you shifting gears during the intervals?
are you sure you are in ERG mode? If so, I don’t understand how your power is so much higher than the first recovery interval, nor how you spike your power at the end of the last interval
Another thing to check would be which gear you’re in. If you’re riding in a really easy gear then you might be near the resistance limit for your trainer? But that would only make sense if you shifted for that last interval
I also have the Direto and use the middle of the cassette with the big ring at the front. No issues.
Any chance you have multiple apps connected to your trainer? I have Zwift and TR open when I train and have only TR controlling the power unit. A couple of times I forgot to disconnect the control function in Zwift and I had similar fluctuations in power level in ERG mode due to competing signals from Zwift and TR.
