Sweet Spot Progression
Thanks! Was your FTP TTE 40 minutes going into this?
Thnx @kurt.braeckel for your questions and other users for the answers…it give me a lot of insights!
This was my experience, almost to a T
Did you guys do no threshold work at all during the block, because I’m considering tacking some SS onto my Saturday vo2max workouts to try and avoid issues if possible.
If you want to do SS after a VO2 session you didn’t go hard enough.
I personally did not do any threshold work during the block. Every ride was either Vo2, Rest, or Z2.
From hearing some experiences of cyclists and coaches much smarter than me, it seemed that the best way to do this block was to focus only on one main adaptation.
Furthermore, in hindsight and during the block, if I were to mix in any other real intensity, my Vo2 workouts wouldn’t have had the same quality, and I do not believe I would have seen the adaptations I have. Even some of the Z2 rides had to turn into just noodling around the block
Edit note - I did 3 workouts per week for 3 week. Normally Tue, Wed, and Fri. Some people do all 3 in a row, then rest and do it again the next week. Some also do 2-a-days… I don’t think I was ready for that this time :slight_smile: . My overall volume dropped a little bit as well, from about 9-11hrs per week to 6-8hrs per week. This was necessary to make the Vo2 sessions hard enough.
Also, the gains I’ve already seen (after dealing with a bit of a plateau pre-Vo2, and after recovering post-Vo2 block) are quite worth it… I wouldn’t worry about losing anything. I feel much better and faster on the bike in just about every way, even though only my Vo2 max “power” saw much of an increase in the first 1-2 weeks back on the bike. Now 5 weeks post-Vo2 block, my FTP and SS workouts are feeling amazing, and I feel much faster on the bike. Able to drop my buddies that were dropping me in the fall, taking KOMs that I haven’t touched in ages. N=1 here :slight_smile:
Nope. When I am able to “properly” execute VO2 max block anything higher than middle of Z2 destroys me. Not to mention mental thing that enables survival mode named “please I do not want to suffer anymore” :wink:
Amen. I made sure I spaced my two VO2 sessions out with a minimum of 3 nights sleep. Monday VO2 max, Thursday or Friday VO2 max. I equate a truly hard VO2 max session to a really hard session in the gym. There’s no way I can do another with one night of sleep between the two.
I haven’t seen any coach prescribe VO2 max on a MWF prescription. I would argue that if you can, you’re not going hard enough. Usually there’s more days of rest between VO2 sessions.
I didn’t do any “threshold”. But I did do some 3x20, 1x45 type sweet spot work “every once in a while” during my Polarized blocks. It doesn’t need to be every week. Like I said, touch it up every 10 days or so.
37min, so yes I rounded up to 40min as a starting point.
Can you share what your VO2 block looked like in terms of progression? I am trying to put mine together right now that does what you have described.
Do you have those FTP progressions saved in a “Team” by chance?
No, but they are super easy to copy out in workout creator.
  1. Sweet Spot Warm up
  2. Interval @ 100% FTP
  3. 5min recovery
  4. Select and repeat 2&3 to meet TiZ
  5. Add in Z2 as needed
  6. 2min cool down
After some thinking it over, I will go ahead and re-test my FTP and see where my TTE ends up and then progress through an intensive block. Thanks for sharing what you’ve done and have planned, that’s very helpful!
How do you all figure your TTE with Over/Unders vs Threshold? I notice @RONDAL has about the same TTE on his O/U and Threshold workouts.
Do you all progress O/U and Threshold as the same “thing”, or progress the two differently?
So I did an extensive SST block before this intensive set. So while the focus on this block is threshold I am still adding in a SST over under workout once a week to get some added stimulus without hitting more threshold which is my Tuesday and Saturday.
I picked the length really just based on trying to target 100-125% TTE while really focusing on extending the intervals to longer time as the primary goal.
Is it right? Dunno. Is it building confidence and getting me a bunch of time right below threshold without the added fatigue of threshold. Yes.
I mean we are talking a 5W decrease on 280W. If the block pays off, I expect to gain that back and then some in relatively short order. Seems my experience is kind of common for this type of training. I don’t think I could have touched up FTP during a block of 8 max VO2 intervals in 18 days. And really, not a big worry. First race is at least eight weeks away yet.
Thanks all for the responses. I figured I was tracking somewhat normally. Based on my Z2 rides and RPE around LT1, HR response to higher powers at Z2, I expect that after a couple of threshold/SST workouts, I’ll regain the sustained mojo pretty quickly. As @anthonylane mentioned, I didn’t touch up threshold and I can’t imagine doing so during that block. Perhaps if it were closer or in a racing season, I’d pyramid it a bit more, but my intent was HARD or really easy.
I ended up doing about 20min at 280W, dialing back for 3 min, and finishing out with 25 min of progressive SST from 250 up to 260, and felt strong at the 260 near the end. Starting out Friday with either 2x30 or 3x20 at 252W (92% of 275 or 90% of 280), then getting serious about it next week and trying to push out to 2hrs at 90% by the end of my block.
So you’re saying add more vo2max intervals :nauseated_face:
I get a weird thing where I just can’t hold the vo2max power, but I can still do SS
The Vo2 max block approach we are referring to says don’t worry about the power :slight_smile: Just make sure you’re going “all out”. But probably yes… more Vo2 max intervals, as much as you can do. Overload hard and recover throughout the block, then recover a lot afterwards and proceed with a higher “ceiling”
Well let’s see how it goes. Plan to do 3 a week for the next 4 weeks. Although I’m doing seilers 4x8 instead of say a hard start approach
