Hello,
I’m currently thinking about buying an Epic Evo S-Works 2023. The bike is fitted with a SRAM XX1 Eagle AXS. I am now thinking about replacing it with a SRAM X0 Eagle Transmission and sell the XX1.
What do you think? Is this a downgrade? I had only read good things about the Transmission so far. I know that the X0 Transmission is a bit heavier, but the shifting performance is supposed to be better.
I have the XO Transmission and thinking of going back to XX1 Eagle AXS. Just my personal recommendation… I’d save the money, you already have a great group set. Update to transmission later when you need to.
Does the frame use a UDH? If not, you won’t be able to upgrade.
Other than that, I’m not sure why you’d buy an XX1 bike only to strip and replace that group? That’s a pricey change, even if you can recoup some of the money on resale of the XX1 stuff.
Thanks for the Help Guys. I keep the XX1
